    [Plugin] Fix Reversed Face Materials
    Scheduled Pinned Locked Moved Solved Plugins
    83 Posts 26 Posters 128.9k Views 26 Watching
      • utilerU
        utiler
        Thanks TIG, clear as crystal now....
        Just Curious...
          A black crystal πŸ˜„
          Faces are or are not well oriented πŸ˜„
          If they are false they must be reverse (material or not) 😲
          Then apply material πŸ˜„
          Maybe I miss something πŸ’š
          • utilerU
            utiler
            maybe you're just a little crazy my man..... πŸ˜‰
            Just Curious...
              Pilou - There is no way of knowing if a particular face is 'the wrong way round'. Especially if an edge has more than two faces.
              The built-in 'Reverse' & 'Orient' will consistently arrange faces that are 'manifold', BUT if you have applied materials to a back-face then that won't flip onto the front-face.
              This tool simply finds all selected faces that have a back-material but no front-material - it then can assume you have modeled them 'wrongly' and it reverses the faces and flips the back-material so it becomes the front-material. keeping the UV-mapping intact etc. This is important when 3rd party applications render the image exactly as you've exported it - i.e. most of them do not render the 'back-faces' at all - rendering only the front-face materials - which in such cases will be the 'wrong' side of the face!
              This might well often look like an 'orient' operation - in the image example all faces do end up correctly oriented too - BUT 'orient' alone would not sort out the wrongly applied materials, as this tool does.
              The tool's 'forced' option is similar, but that works even if a selected face with aback-material that has a front-material, reversing the face and using the back-material on the front-face instead and defaulting the back-material - because it is more 'dangerous' its sphere of operation is more limited...
                That the Knot πŸ˜„
                In your image example walls have not thick, does the plug works also with thick walls ?
                I suppose yes but... πŸ˜„
                  The tool works for any faces - as long as they only have a material on the back and not the front.
                  It simply reverses the face whilst leaving the materials in the same 'location' [orientation].
                  With an 'un-fixed' face - flick between Textured Mode and Monochrome Mode to reveal faces that are 'wrongly' oriented but have their materials on the back so look OK in the SKP-render BUT will fail in the external-renderers.
                  With a face that's 'fixed' it looks the same in the SKP 'Texture Mode', but it will then render properly in renderers [the Monochrome Mode should then show all faces oriented the same]
                    Here's v1.4 http://forums.sketchucation.com/viewtopic.php?p=264134#p264134
                    It has an additional Tool 'Reverse Faces and Materials' - this reverses faces keeping their materials with correct UV-mapping - effectively turning the form 'inside out': if it is 'brick' outside and 'wood' inside with the 'back-faces' oriented to the 'outside', then using the tool reverses the faces so that the back-faces are oriented to the 'inside', AND now the 'wood' material will be on the 'outside' and the 'brick' material will be on the 'inside' - UV-mapping will have been correctly reapplied.
                    For example I recently had an imported OBJ object that had all some objects with faces reversed ['blue' outwards] and so their materials were mapped [correctly] on their 'insides'. Simply 'reversing' the faces failed to keep the UV-mapping on the new face orientations [on 'smoothed' surfaces it's especially problematical] - but this tools now solves that problem.
                    The included lingvo files have all been updated to match the changes.
                    • P
                      pmolsen
                      @tig said:
                      Note: Groups and Component-Instances that can have materials applied
                      directly onto them - then any faces within them that have the default-
                      material [front and/or back] will then appear to have that material applied
                      to them. In fact these faces within the Group/Definition will still have
                      the default-materials [front and/or back]. If you want to quickly remove
                      the appearance of this material on the back-faces within the group then
                      explode the group and immediately regroup the geometry - the group's
                      previous material will then be individually transfered to each face that
                      had the default-material. Now use this 'Delete Back-Materials' to delete
                      the unneeded back-material.
                      Excellent plugin! Exactly what I have been waiting for.
                      I think I must be missing something with your above comment though. As you say if a group or component is textured with a material without first opening the group or component, all untextured faces, including the back faces, appear to be painted with that texture.
                      To fix the problem there is no need to ungroup and regroup as stated above. Simply select the default texture (either from the materials window or by sampling an untextured front or back face) then paint the unopened group or model. All untextures faces go back to untextured the way they should be.
                      • P
                        pmolsen
                        When I start Sketchup after installing the plugin I get the following error:
                        Error Loading File FixReversedFaceMaterials.rb
                        No such file to load -- deBabelizer.rb
                        I checked the zip file and there is no such file in it. I found a copy in the Lattice Maker plugin but it should really be in this one as well.
                        Also what is the Sketchup8 link that is installed in the subfolder?
                          Sorry about this... it is always the same 'deBableizer.rb' file... BUT I have now added it to the zip [ http://forums.sketchucation.com/viewtopic.php?p=264134#p264134 ] - it was packaged with the earlier zipped versions, but I missed it out of this one 😳
                          I also managed inadvertently to add a shortcut linking to my copy of SUp v8 [luckily it's all public now anyway] - but that's now gone too !!! I just had a really bad day πŸ˜’
                            Aerilius
                            No problem, that shortcut was not dangerous πŸ˜„
                            Many thanks, this is the best reversed-faces-plugin that I ever found πŸ‘
                            I saw, maybe you'd like to have a german translation πŸ˜‰
                            new german translation
                              Thanks for the DE lingvo.
                              I'll include it in any future release - unless someone else wants to jump in with another version or comments...
                              My German is not up to much [as you probably noticed!]... πŸ˜‰
                                Here's a tweaked German lingvo file [by Aerilius]...FixReversedFaceMaterialsDElingvo.zip
                                • E
                                  Ecuadorian
                                  Thank you, TIG!
                                  This is a life saver... πŸ‘
                                  -Miguel Lescano
                                    Here's another version of the DE lingvo [by User2012] - try them and choose which you want...FixReversedFaceMaterialsDE.zip
                                    • E
                                      Eugenegoth
                                      Thank you TIG!!!!
                                        Any chance this could be compiled under a menu? πŸ˜•
                                          No sooner said than done - here's v1.5 with the four tools under one submenu http://forums.sketchucation.com/viewtopic.php?p=264134#p264134
                                          πŸ€“
                                            Thanks πŸ‘
                                            I've a file that doesn't remove backface materials πŸ˜•
                                            • 2 / 5
