    Vidro Global Illumination Render
    extensions
    14 Posts 7 Posters 5.2k Views 7 Watching
      Jim
      Ran across this and don't think it's ever been mentioned here, so here it is.
      http://www.vidro-project.com/
      and translated:
      http://translate.google.com/translate?sl=ja&tl=en&u=http://www.vidro-project.com/
        tak2hata
        Hi!
        I made exporter for vidro render.
        http://onigiriburning.so.land.to/
        The explanation about my exporter named "SU2OBJMTL" is not good because I am not good at English.
        if you interested this , please try "SU2OBJMTL".
        Thanks.
        by TAK2HATA
        • P Offline
          Panga
          Thanks a lot for these exporters !! I wanted to try luxrender and Sunflow for a while but never find a way to export my SU models.
          Luxrender exporter works fine, but I had an error with the sunflow exporter, I think it's about sunflow installation, I'll give a look further as soon as I can.
          Cheers.
            tak2hata
            Cheers.
            Hi,Panga.
            In using sunflow render, you must have java runtime.
            And Exporting by su2objmtl need batch file in the sunflow folder.
            Create New text file and change file name.
            The file name recommend is "sunflow.bat"
            Open it with text editor.
            Exsample batch code...
            @cd C;\Program Files\Java\jre1.5.0\bin
            @java.exe -jar c;\sunflow\sunflow.jar %*
            You need change path in this code, appropriate for each files and folders.
            If you can run jar file directly on your machine,
            Perhaps this may work, too.
            Please select the created batch file for "Render engine path" on the dialog of sunflow exporter.
            Sorry for my english is poor.
            Thanks.
            by TAK2HATA
              Camara
              I just saw your exporters and try them out. Your work is amazing! I been looking for a obj exporter from SU and yours works like a charm!!!! Tanks!
              I model both in SU and Blender, but there was no direct way to export a model from the free version of SU to Blender. I always use the SU2KT plugin to export to Kerkythea XML file and then use the program Kt2Obj (http://www.nicetuna.com/kt2obj) to transform the Xml to Obj and open the obj in Blender.
              If you don´t mind I ill post on the blender forum a link to your plugin, because there are a lot of Blender user's that will find your plug-in very useful.
              The Luxrender plug-in is very good as well, but is a pity there is no material editor in it. There are attempt's to get a working SU plug-in in the Luxrender forums but the development is very slow, maybe you could give them a hand. Your plug-in is already better that them.
              Portfolio: http://camara.weebly.com/
                Jim
                Blender can't use the COLLADA export included in SketchUp Free and Pro?
                  Camara
                  Blender imports COLLADA with no problem but I never could get the export from SU to work. It always freezes and doesn't export's a DAE file. Maybe is just me I don´t now.
                  • N Offline
                    notareal
                    @tak2hata said:
                    Hi!
                    Thanks.
                    Nice. This would need a own topic (if not exist yet). 😍
                    • Didier BurD Offline
                      Didier Bur
                      @ tak2hata: are you aware of this: http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=427
                      Maybe it could be of some use for your sunflow exporter.
                      Regards,
                      DB
                        tak2hata
                        @didier bur said:
                        Regards,
                        Hi, Dider Bur.
                        It was your su2sf.rb to refer most when I began to study Ruby first.
                        That is very useful!
                        The method of getting mesh infomation from sketchup were learnt by enjoying su2sf.rb with Sketchup API Reference in my hand.
                        Finally, I tried to make exporter to Vidro Renderer for study, and to bring it together as exporter to general-purpose OBJ file afterwards.
                        Sketchup obj exporter is already exists in this forum.It made by TIG.
                        I think that making the topic for my exporter confuses this forum.
                        So I arranged my su2objmtl on my site without contributing here.
                        Best Regards!
                        by TAK2HATA
                        • V Offline
                          vidy
                          sorry guys, firstly thanks to tak2hata for the converter,
                          secondly, probably this is the noob question, how can i adjust the view on vidro?
                          thanks
                          still so much to learn..
                            tak2hata
                            thanks
                            If you copy both "su2objmtl.rb" and ""su2objmtl_vidro.rb" in your sketchup plugins folder,
                            You will find "Vidro render exporter" in sketchup plugins menu bar.
                            Select "export setting" and show webdialog for Vidro render exporter.
                            Firstly click "EXPORT!" button.
                            Asking dialog to find path of vidro.exe.
                            Select vidro.exe ,then start rendering.
                            If you miss selecting path, "Select path" button in the webdialog helps you.
                            Thanks.
                            by TAK2HATA
                            • V Offline
                              vidy
                              thank you tak2hata, will try and report it.. 👍
                              regards,
                              • V Offline
                                vidy
                                its absolutely wonderful tak2hata.. 😲
                                just need a bit tutorial on how the material attached
                                first try:
                                http://a.imageshack.us/img137/6580/ketewel01.jpg
                                regards,
