    Are opacity settings available for imported jpegs?
    layout
    4 Posts 3 Posters 3.8k Views 3 Watching
    • keea1111K Offline
      keea1111
      HI,
      Does anyone know if you can change the opacity of a JPEG(or PDF) that you import into LO? I've been trying to make that work, with no success? Much thanks,
      KEEA
        I think not - have you tried saving the image as a PNG instead ?
        • keea1111K Offline
          keea1111
          Yes, I tried with a PNG file, but can't get it to work. Does it work for you with PNG? If so, how did you do it? thanks,
          KEEA
            TIG means that you can edit a png image in an external editor and add transparency to it. You cannot interactively adjust its transparency in LO so you have to find out how much you want to adjust it in your image editor and then get stuck to it.
