    Source or method of creating translucent materials
    3 Posts 3 Posters 866 Views 3 Watching
      CalypsoArt
      I've found many sources for materials of all types. However, I've only been using the standard included SU transparent materials. Any sources for others, or instructions on how I can make my own?
        Translucency/Transparency is controlled here....
        You can load any supported image type here...
        So it's very easy to create your transparent library
          You can also use a transparent image [PNG file] as a texture, and then even with the material's opacity set at 100% you can see through a face that uses it and it will still cast shadows even when very transparent [ http://forums.sketchucation.com/viewtopic.php?p=260915#p260915 ] - unlike simple materials where low opacity settings stop casting shadows... you need to decide which way you want this to happen........
