    Texture from url?
    39 Posts 10 Posters 7.8k Views 10 Watching
    • TIGT Online
      What's this then ?
      <a href="java script&#058;void(0);" onclick="document.execCommand('SaveAs',true,'http://fileden.com/somefolder/some file.mp3');">download</a>
      There's just not a 'Save' version ???
        Jim
        I've never heard of "execCommand" before, but I'd be surprised if it were cross-platform. If it existed, we probably wouldn't be having this discussion.
        • TIGT Online
          Perhaps a MAC users could confirm...
            ben.doherty
            While the JS debate rages, I've been playing with what can be done with ruby (being single-minded/stubborn/lazy)
            I've updated my !loadpaths file to match dan's latest http://forums.sketchucation.com/viewtopic.php?f=180&t=29412&hilit=load+path#p257058
            and when I try a couple of things I get this response:
            require 'net/http' Error: #<LoadError: C:/ruby186/lib/ruby/1.8/net/protocol.rb:21:inrequire': No such file to load -- socket>
            require 'date/format'
            true`
            Any ideas on why net/http fails, but date/format works?
            I'm sure it will take some clever file management, and refresh cycle control etc, but it'd be cool to be able to specify a url to get a texture from. That'd open up a load of opportunities for data vis etc.
              Jim
              That means it couldn't find the file (socket.so) in the load path.
              For a short-term solution, you could try to copy socket.so to the Plugins folder.
              • Dan RathbunD Offline
                Dan Rathbun
                It's HTML 5 me thinks. And seems Microsoft may have added a bunch of standard CommandIDs without getting them approved by the web community (as usual.) The spec implies browser specific IDs should have a prefix like "IE-", but MS has been doing this 'arm-twisting' for years.
                See: http://www.w3.org/TR/html5/author/dom.html#execCommand
                MSDN: http://msdn.microsoft.com/en-us/library/ms536419(v=VS.85).aspx
                and MS' command IDS: http://msdn.microsoft.com/en-us/library/ms533049(v=VS.85).aspx
                I'm not here much anymore.
                  Ben_M
                  Hello!
                  Has anyone made any progress on a simple, cross platform solution to this in the past few months?
                  Thanks,
                  Ben
                  • V Offline
                    Viskiz
                    I solved in on Windows platform.
                    In my script installation I included ruby lib files needed for http, so users will have them after installing script.
                    The code followed in script:
                    $LOAD_PATH << File.join(MY_PLUGIN_HOME, "bin", "rblib")
                    Sketchup::require 'uri'
                    Sketchup::require 'net/http'
                    Installer for MAC OS should have different ruby library files I think. I haven't MAC yet, so I can't tell any more. Let me know if you solve it.
                      Jim
                      You may be interested in this plugin effort - downlod files plugin using the cUrl library.
                      • K Offline
                        kaas
                        Digging up this old thread because I'm trying to do almost the same as the OP. Since the last post in this topic, Ruby has been updated so I'm hoping its more simple now.
                        I have been trying several methods. This code saves the image in the local documents folder so I could pick it up there etc.
                        require 'net/http'
                        Net;;HTTP.start("www.google.nl") do |http|
                            resp = http.get("/images/branding/googlelogo/1x/googlelogo_color_272x92dp.png")
                            open("googlelogo_color_272x92dp.png", "wb") do |file|
                                file.write(resp.body)
                        puts "Done"
                        Problem is, my images need a different type of url. Something like:
                        https://url/coordinates/?key=1234abc&index=0
                        This sort of link doesn't work in the code above.
                        Another method I'm trying is loading the image in a webdialog and then grabbing it from Ruby.
                        The test html code (the url could easily replaced with the actual https code) is:
                        <!DOCTYPE html>
                        <html><head></head><body>
                        <img id ="webimage" src = "https://www.google.nl/images/branding/googlelogo/1x/googlelogo_color_272x92dp.png">
                        </body></html>
                        And to grab the image in ruby:
                        img = @wd.get_element_value('webimage')
                        Of course this doesn't work because the image isn't a value. I'm stuck.
                        Anyone has a suggestion? That would be very welcome.
                        • TIGT Online
                          Something like this should work:
                          require('open-uri')
                          fail = false
                          url = "http://www.google.nl/images/branding/googlelogo/1x/googlelogo_color_272x92dp.png"
                          file = File.join(Dir.pwd, File.basename(url))
                          begin
                          	download = open(url)
                          rescue Exception => error
                          	puts "#{error}"
                          	fail = true
                          unless fail
                          	begin
                          		File.delete(file) ### in case it exists
                          	rescue
                          	begin
                          		IO.copy_stream(download, file)
                          		puts "#{error}"
                          It should work with a 'php' formatted URL, but remember that then you need to parse out the file name another way. Perhaps [assuming 'key=' gives the file name] split the URL at '?', then take [1], then split at '&', then find the array element starting "key=", then split that at '=' and then [1] is the file name given by 'key=' ?
                          I also saved the downloaded image file in the 'current directory', but you can of course choose any other folder you want...
                          • K Offline
                            kaas
                            Thanks for the reply TIG. Your code does download a file but when trying to open it I get:
                            Decode Error! Invalid or unsupported PNG file
                            Edit:
                            I was also trying with net/http. It does work with simple files but the actual https request still fails.
                            • K Offline
                              kaas
                              In case someone runs into the same question. It seems to work now.
                              require 'net/http'
                              require 'tempfile'
                              uri = URI('https://www.google.nl/images/branding/googlelogo/1x/googlelogo_color_272x92dp.png')
                              model = Sketchup.active_model
                              materials=model.materials
                              m = materials.add "Test Color"
                              loc = ''
                              begin
                              	request = Net;;HTTP;;Get.new uri
                              	Net;;HTTP.start(uri.host, uri.port,
                                ;use_ssl => uri.scheme == 'https') do |http|
                              	  http.request(request)
                              	  response = http.request request # Net;;HTTPResponse object
                              		file = Tempfile.new(['foo','.png'], Dir.tmpdir, 'wb+')
                              	  begin
                              			file.binmode
                              			file.write(response.body)
                              			file.flush
                              			loc = file.path.gsub("/", '\\\\\\')
                              	  ensure
                              			file.close
                                puts e.message
                              m.texture = loc
                              m.texture.size = [m.texture.image_width.to_m, m.texture.image_height.to_m]
                                driven
                                for completeness you need a conditional for osx
                                 loc = file.path if Sketchup.platform == ;platform_osx
                                john
                                  Dan Rathbun
                                  When a image is loaded as a web page resource, it is present in the "Temporary Internet files" folder. But some security settings might prevent the copying of a file from there to a trusted local folder.
                                  Anyway:
                                  require "FileUtils"
                                  then try the copy method.
                                  See: http://ruby-doc.org/stdlib-2.0.0/libdoc/fileutils/rdoc/index.html
                                  • K Offline
                                    kaas
                                    John and Dan, good suggestions. Thanks
                                      When you say different type of URL, what do you mean? HTTPS?
                                      • K Offline
                                        kaas
                                        Yes, something like https://url/coordinates/?key=1234abc&index=0
                                          For HTTPS connections you need to enable SSL when you create the HTTP connection.
                                          Note that there's a bug in Ruby that shipped with SU2014-2016 that might cause problems under Windows where the shipped SSL certificates might not work.
                                          • 2 / 2
