    Texture from url?
    39 Posts 10 Posters 7.9k Views 10 Watching
      Jim
      @tig said:
      [on PC]
      Exactly.
      The most beneficial result from this thread would be a cross-platform download library which could be used for images or anything, really.
        But the original inquiry was 'for PC' ?
        A pure Javascript version can't work [?] - because of security issues there is no plain 'save' - only 'save_as', to you ensure you know what's going on with downloading things off the www onto your PC...
        The 'vbs' method will work for PC - there's probably an equivalent AppleScript [type] method for the MAC... but I can't see how a 'cross-platform' version might work πŸ˜•
        Java is inherently 'limited' as I said...
          Jim
          I think it can. There is no save or save as in JavaScript. You can save to disk using JavaScript, but there isn't a cross-platform solution. On Windows, you would use a FileSystem activex object. The same scripting host that rtuns the .vbs can run .js also.
          But, the XHR is available on all (important) browser platforms. So a cross-platform solution is to use a WebDialog, fetch the file using the XHR, then pass it to the ruby plugin for saving to disk.
          This small library is a good example of using a XHR cross-platform:
          http://code.google.com/p/microajax/
          if (window.ActiveXObject)
          return new ActiveXObject('Microsoft.XMLHTTP');
          else if (window.XMLHttpRequest)
          return new XMLHttpRequest();
          return false;
            What's this then ?
            <a href="java script&#058;void(0);" onclick="document.execCommand('SaveAs',true,'http://fileden.com/somefolder/some file.mp3');">download</a>
            There's just not a 'Save' version ???
              Jim
              I've never heard of "execCommand" before, but I'd be surprised if it were cross-platform. If it existed, we probably wouldn't be having this discussion.
                Perhaps a MAC users could confirm...
                • B
                  ben.doherty
                  While the JS debate rages, I've been playing with what can be done with ruby (being single-minded/stubborn/lazy)
                  I've updated my !loadpaths file to match dan's latest http://forums.sketchucation.com/viewtopic.php?f=180&t=29412&hilit=load+path#p257058
                  and when I try a couple of things I get this response:
                  require 'net/http' Error: #<LoadError: C:/ruby186/lib/ruby/1.8/net/protocol.rb:21:inrequire': No such file to load -- socket>
                  require 'date/format'
                  true`
                  Any ideas on why net/http fails, but date/format works?
                  I'm sure it will take some clever file management, and refresh cycle control etc, but it'd be cool to be able to specify a url to get a texture from. That'd open up a load of opportunities for data vis etc.
                    Jim
                    That means it couldn't find the file (socket.so) in the load path.
                    For a short-term solution, you could try to copy socket.so to the Plugins folder.
                    • Dan RathbunD
                      Dan Rathbun
                      It's HTML 5 me thinks. And seems Microsoft may have added a bunch of standard CommandIDs without getting them approved by the web community (as usual.) The spec implies browser specific IDs should have a prefix like "IE-", but MS has been doing this 'arm-twisting' for years.
                      See: http://www.w3.org/TR/html5/author/dom.html#execCommand
                      MSDN: http://msdn.microsoft.com/en-us/library/ms536419(v=VS.85).aspx
                      and MS' command IDS: http://msdn.microsoft.com/en-us/library/ms533049(v=VS.85).aspx
                      I'm not here much anymore.
                      • B
                        Ben_M
                        Hello!
                        Has anyone made any progress on a simple, cross platform solution to this in the past few months?
                        Thanks,
                        Ben
                        • V
                          Viskiz
                          I solved in on Windows platform.
                          In my script installation I included ruby lib files needed for http, so users will have them after installing script.
                          The code followed in script:
                          $LOAD_PATH << File.join(MY_PLUGIN_HOME, "bin", "rblib")
                          Sketchup::require 'uri'
                          Sketchup::require 'net/http'
                          Installer for MAC OS should have different ruby library files I think. I haven't MAC yet, so I can't tell any more. Let me know if you solve it.
                            Jim
                            You may be interested in this plugin effort - downlod files plugin using the cUrl library.
                            • K
                              kaas
                              Digging up this old thread because I'm trying to do almost the same as the OP. Since the last post in this topic, Ruby has been updated so I'm hoping its more simple now.
                              I have been trying several methods. This code saves the image in the local documents folder so I could pick it up there etc.
                              require 'net/http'
                              Net;;HTTP.start("www.google.nl") do |http|
                                  resp = http.get("/images/branding/googlelogo/1x/googlelogo_color_272x92dp.png")
                                  open("googlelogo_color_272x92dp.png", "wb") do |file|
                                      file.write(resp.body)
                              puts "Done"
                              Problem is, my images need a different type of url. Something like:
                              https://url/coordinates/?key=1234abc&index=0
                              This sort of link doesn't work in the code above.
                              Another method I'm trying is loading the image in a webdialog and then grabbing it from Ruby.
                              The test html code (the url could easily replaced with the actual https code) is:
                              <!DOCTYPE html>
                              <html><head></head><body>
                              <img id ="webimage" src = "https://www.google.nl/images/branding/googlelogo/1x/googlelogo_color_272x92dp.png">
                              </body></html>
                              And to grab the image in ruby:
                              img = @wd.get_element_value('webimage')
                              Of course this doesn't work because the image isn't a value. I'm stuck.
                              Anyone has a suggestion? That would be very welcome.
                                Something like this should work:
                                require('open-uri')
                                fail = false
                                url = "http://www.google.nl/images/branding/googlelogo/1x/googlelogo_color_272x92dp.png"
                                file = File.join(Dir.pwd, File.basename(url))
                                begin
                                	download = open(url)
                                rescue Exception => error
                                	puts "#{error}"
                                	fail = true
                                unless fail
                                	begin
                                		File.delete(file) ### in case it exists
                                	rescue
                                	begin
                                		IO.copy_stream(download, file)
                                		puts "#{error}"
                                It should work with a 'php' formatted URL, but remember that then you need to parse out the file name another way. Perhaps [assuming 'key=' gives the file name] split the URL at '?', then take [1], then split at '&', then find the array element starting "key=", then split that at '=' and then [1] is the file name given by 'key=' ?
                                I also saved the downloaded image file in the 'current directory', but you can of course choose any other folder you want...
                                • K
                                  kaas
                                  Thanks for the reply TIG. Your code does download a file but when trying to open it I get:
                                  Decode Error! Invalid or unsupported PNG file
                                  Edit:
                                  I was also trying with net/http. It does work with simple files but the actual https request still fails.
                                  • K
                                    kaas
                                    In case someone runs into the same question. It seems to work now.
                                    require 'net/http'
                                    require 'tempfile'
                                    uri = URI('https://www.google.nl/images/branding/googlelogo/1x/googlelogo_color_272x92dp.png')
                                    model = Sketchup.active_model
                                    materials=model.materials
                                    m = materials.add "Test Color"
                                    loc = ''
                                    begin
                                    	request = Net;;HTTP;;Get.new uri
                                    	Net;;HTTP.start(uri.host, uri.port,
                                      ;use_ssl => uri.scheme == 'https') do |http|
                                    	  http.request(request)
                                    	  response = http.request request # Net;;HTTPResponse object
                                    		file = Tempfile.new(['foo','.png'], Dir.tmpdir, 'wb+')
                                    	  begin
                                    			file.binmode
                                    			file.write(response.body)
                                    			file.flush
                                    			loc = file.path.gsub("/", '\\\\\\')
                                    	  ensure
                                    			file.close
                                      puts e.message
                                    m.texture = loc
                                    m.texture.size = [m.texture.image_width.to_m, m.texture.image_height.to_m]
                                      driven
                                      for completeness you need a conditional for osx
                                       loc = file.path if Sketchup.platform == ;platform_osx
                                      • Dan RathbunD
                                        Dan Rathbun
                                        When a image is loaded as a web page resource, it is present in the "Temporary Internet files" folder. But some security settings might prevent the copying of a file from there to a trusted local folder.
                                        Anyway:
                                        require "FileUtils"
                                        then try the copy method.
                                        See: http://ruby-doc.org/stdlib-2.0.0/libdoc/fileutils/rdoc/index.html
                                        • K
                                          kaas
                                          John and Dan, good suggestions. Thanks
                                            When you say different type of URL, what do you mean? HTTPS?
                                            • 2 / 2
