    Find and replace multiple components?
    30 Posts 9 Posters 12.8k Views 9 Watching
      tenquin
      Olá TIG!
      Boa tarde!
      Obrigado pelo retorno.
      Desculpe se não soube me expressar corretamente, na verdade preciso que o plugin troque todos os componentes que tem um parâmetro específico, no caso o parâmetro "modeloptions=portas inferiores"
      Desde já agradeço.
      Esses seriam os parâmetros de exemplo
      Essa seria o componente a ser trocado, sendo que teria que manter as dimensões lenx, leny, lenz e posições x,y,z....
      Essas seriam as portas de troca e estariam em uma biblioteca...
      • TIGT Online
        @tenquin
        Yes, that's nothing like it !
        You could try editing the code...
        dcs.each{|d|
          next unless d.get_attribute("dynamic_attributes", "modeloptions", "") == "portas inferiores"
          # this skips if it's not that type of dc ???
          p d.name # to see their names listed in the Ruby Console
          d.instances.each{|i| i.definition = defn }
          # replace with original
          tenquin
          Obrigado mais uma vez TIG!
          Vou estudar mais um pouco e tentar fazer,
          sou novo em programação mas vou tentar até conseguir. rsrs
            tenquin
            @tig said:
            OK
            Let's consider this...
            The original component is named [let's say] "DC" - so its unique-ified siblings are named DC#1, DC#2 etc...
            So we can search the model's definitions for matching 'patterns' and replace their instances...
            The naming has to be logical, and all instances the same...
            > model=Sketchup.active_model
            > defns=model.definitions
            > name="DC" # perhaps you'd use an inputbox to get this 'name' ?
            > defn=defns[name]
            > dcs=defns.find_all{|d| d.name =~ /^#{name}#/ }
            > # note how 'name' starts the match-pattern and has a following #
            > model.start_operation("Un-unique #{name}", true) # one-step undo
            > puts "Un-unique #{name}"
            > dcs.each{|d|
            > model.commit_operation
            > puts "Done"
            This works within nested components etc...
            You could check that the geometry/size etc of the instance of the original defn matches the instance of the to-be-un-uniqued definition, but that requires more convoluted code...
            Olá TIG
            Desculpe minha insistência.
            Há alguns meses conversamos sobre o código acima, que faz um script que substitui componentes.
            Ainda não consegui fazer com que funcionasse, criei um componente com nome DC e copiei e colei o código no console Sketchup,mas não obtive resultado.
            Estou me dedicando a Ruby, mas mesmo depois de ler o livro Automatic Skechup, não consegui identificar o que está errado...
            • TIGT Online
              What results do you get ?
              The Ruby Console will show errors and output.
              You are looking for a component definition name, NOT a component instance name.
              They are different things.
              The component's name is displayed in the Components Browser.
              Instances can have different names from their definition - this shown in Entity info - if it's selected...
                tenquin
                @TIG
                Obrigado mais uma vez por responder.
                Não retorna nenhum erro, porém nenhum resultado também. Segue uma imagem.
                Minha intenção é buscar os componentes por atributos dinâmicos ao invés de por nome, se poder me dá uma luz de como ficaria o código assim eu agradeço, se não, depois tentarei editar o código para se adequar ao que desejo.
                • TIGT Online
                  What else do you expect ?
                  You have 1 component definition named 'DC'.
                  If you had more using that name pattern - e.g. 'DC#1', DC#2' etc.
                  Then DC would prevail !
                  The code is working just fine - but your model has got nothing in it to be processed !
                    tenquin
                    Perdão TIG.
                    Você tem razão, eu não estava sabendo usar o código corretamente.
                    Agora me parece que está funcionando.
                    Obrigado
                    • K Offline
                      kostiaarh
                      @tig said:
                      IF you name your components logically then a script in the form swapcomponents("-aaa","-bbb") is straightforward - and quite simple - I can talk you through it... Once you have something working vis the Ruby Console it#s easy enough to add a menu item and dialog, even a toolbar and so on...
                      First off - make a logical component-naming strategy/
                      Then write is a simple step-sheet explaining how you'd like to use the new tool... e.g.
                      I select various cabinets where I want to swap one type of door [and drawer] for another.
                      I activate the new tool tell it what code to find and what code to replace it with... and it automatically finds equivalent doors [and drawers] in the model [or perhaps SKPs in folder[s]] in ../Components/.
                      It then uses/loads them and replaces the current component instance with the required definition.
                      A dialog reports what's been changed and/or any errors.
                      It is one step undo-able.
                      For example always name doors 'Door-WWW-HHH-FINISH-CODE' and then all we have to do is swap components with the same base but a new FINISH and/or CODE - In the input you could type Door*-Oak-A and in the output type Door*-Maple-A and all doors code A would change from 'Oak' to 'Maple'; or Door*-A >>> Door*-B would swap from code A to code B - if there were no Oak versions of code B doors then the closing dialog tells you!
                      On a more global system *-A >>> *-B tries to swap all type A 'fitments' to type B.
                      If things are 'nested' - components inside groups etc then it's more tricky but not impossible...
                      You could also swap ironmongery from Handle-*-A >>> Handle-*-B.
                      See the schema ?
                      TIG can I ask you to post an example of this code here? Thanks.
                      • TIGT Online
                        You quoted my example of a step sheet...
                        Please outline exactly what you want to do - what to find by a pattern-match and how to rename them etc...
                        This thread have been around for a decade !
                        So what you want to do needs to be specified very precisely...
                        • 2 / 2
