    Move multiple entities to z = 0 ?
    6 Posts 4 Posters 1.3k Views 4 Watching
      danbig
      I think I saw a solution to this a while back, but I can't find it now.
      I have an imported CAD file that appeared to be 2d, but upon examination, the lines are spread out along the z axis.
      Is there a way I can select all of these objects, and move them to z=0 with one command?
      This is a "left" view of what should be a flat parking lot. The green axis is along the bottom of the image. I don't want to change the x or y locations of any of the objects.
      • X Offline
        xrok1
        if you have fredoscale, you can group them then scale them in the z to "0".
        โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
          danbig
          Perfect. Thanks.
          • X Offline
            xrok1
            ๐Ÿ˜‰ its kinda silly that the SU scale tool won't allow 0 scale, but thanks to Fredo we have it!
            Thanks again Fredo. ๐Ÿ˜„
              I think you are looking for 'flatten' - it's built-in the AutoCAD [Express tools] - flatten the CAD file before you import it... or in Sketchup something similar is available at Smustard.com. There's also Fredo's scale tool.
              There are also other 'manual' alternatives - e.g. make a large flat rectangle face below everything, then use SUp's Sandbox > Drape tool to 'drape' the form vertically down onto the rectangle face - all lines are now 'flat' in the Z... Erase the original and the unwanted edges of the rectangle face... ๐Ÿค“
              • AnssiA Offline
                Anssi
                If you have SU Pro, you can export a 2D plan view DWG, and re-import that
                Anssi
