    Error loading file projectsketch loader?
    4 Posts 3 Posters 494 Views 3 Watching
    • L
      lapx
      I'm geting and error message on opening a new drawing which i have no idea what programs its effecting. I have always ignored it. Anyone have a solution to solving the error..."error loading file projectsketch loader"?
      Thanks,
      • C
        CJRyan
        Just a wild guess. Because I might be the least experienced person here. But I think you might be missing a file that "projectsketch" loader needs. I'm only saying this because I got a similar message from "window tools" and it was because I was missing a file it needed.
        http://wiki.renderplus.com/index.php?title=ProjectSketch
        • TIGT
          Have you installed projectsketch ?
          It seems it is not correctly installed.
          I suspect some files that should be in a sub-folder aren't getting found.
          Have you being moving files around ?
          You could try installing it again...
          BUT if you don't want projectsketch to load at all then you need to find its .rb file in the ../Plugins/ folder and rename it with a .txt suffix, so then it doesn't auto-load... restart SUp and the error should have gone away...
          • L
            lapx
            Thanks Guy's
            I couldnt remeber what it was so I deleted all the related files which got rid of the error messages. Thanks for the link Cj, if I decided to use it I'll relosad it more carefully. ☀
