    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    FL/Y lamp
    19 Posts 13 Posters 4.1k Views 13 Watching
    • massimoM Offline
      massimo Moderator
      A very small thing...A methacrylate lamp by Kartell. It's called FL/Y.
      Modeled in Sketchup. The illustrative renders are raw Kerkythea outputs.
      Hope it's useful. πŸ˜„
      fly_lamp.zip
        Pop generation 😎
        • olisheaO Offline
          olishea
          and nice renders!! πŸ‘
          oli
          • massimoM Offline
            massimo Moderator
            Thanks Oli. Cheers πŸ˜„
            • P Offline
              Pg09
              I love it and thanks for the model!
              Very generous!
              • massimoM Offline
                massimo Moderator
                You're welcome Pg09. πŸ˜„
                  bocomofo
                  Nice design and nice model, thanks for sharing
                  Those renders are tip top too!
                  • massimoM Offline
                    massimo Moderator
                    Thanks Joe. πŸ˜„
                    • majidM Offline
                      majid
                      simple, clear and realistic. it is what I like πŸ˜„
                      • massimoM Offline
                        massimo Moderator
                        Glad you like it Majid. πŸ˜„
                          sepo
                          wow...I was fooled by the renders. πŸ‘
                          • massimoM Offline
                            massimo Moderator
                            Cheers Sepo. πŸ˜„
                              smellerbee
                              After my long search i've finally found the lamp for my current project.
                              thanx a bunch,
                              Durrant
                              • CAntonisC Offline
                                CAntonis
                                In a simple model you find greatness.
                                The render looks amazingly real.I was fooled too.
                                Thank you for the model.
                                • massimoM Offline
                                  massimo Moderator
                                  You're welcome. πŸ˜„
                                    anstvam
                                    I was fooled BIG TIME by the renders...
                                    Anastassis
                                    We are all in the gutter, but some of us are looking at the chintz...
                                      madhav
                                      Great stuff. Many thanks.
                                        jpalm32
                                        Thanks, Nice!
                                        • irwanwrI Offline
                                          irwanwr
                                          @massimo said:
                                          ... raw Kerkythea outputs.
                                          that's a raw KT outputs!? wow πŸ‘
                                          thank you for sharing.
