    Selecting from an image?
    10 Posts 6 Posters 1.3k Views 6 Watching
    • BoxB Offline
      I'm wondering if it is possible to import an image and select part of it as a shape that can then be push pulled etc. Like using a mask in programs like Photoshop?
      As a simple example.
      I would like to select just the black silhouette and lose the white background.
      http://i155.photobucket.com/albums/s296/storeben/Sculpt/Fig.jpg
        @box said:
        ...I would like to select just the black silhouette and lose the white background...
        Well, if I could have a choice, I would also go for the black part of the image!
        πŸ˜„
        Anyway, joking aside; there is ImageProfile at Smustard (commercial plugin however; you need to "subscribe" to a certain amount of "credits" that are processed on their server)
        http://www.smustard.com/script/ImageProfile
        • BoxB Offline
          That looks interesting Gaieus, I'll keep it in mind,I'm not sure about the credits and server part of it as I spend a lot of my time without an internet connection.
          Come to think of it, I drew that shape in Corel and exported it as a DWG so that I could have it watercut out of a thick piece of glass, can I import from the DWG as a shape?
            Sure that's the best choice. If you have SU Free (7.1 or above) however, you will need this plugin to import dwg/dxf
            • BoxB Offline
              Excellent, thanks for the help once again.
                Aerilius
                Another possibility would be to vectorize the image (this black/white example is perfect), and then import the lines.
                I have not tested, but the following workflow should do it:
                1. Download the free vector editing program Inkscape
                  Path -> vectorize bitmap
                2. delete the image (in the background) and save as .svg
                3. Download an svg-import script for Sketchup: http://www.uli-tessel.de/suruby.htm
                  and import the outlines
                • BoxB Offline
                  Thanks Aerilius, I've made a note of this and will give it a try.
                  • shuraS Offline
                    shura
                    Dear Aerilius,
                    this is an interesting workflow, I'd like to make it work for me too. Unfortunately I don't get the svg.rb to work. It needs some other ruby scripts that are not specifically SU related (I think). At this point my knowledge ends... maybe some ruby-wizard can help us out here?
                    all I get is this:
                    Error Loading File svg.rb
                    No such file to load -- rexml/parsers/pullparser.rb
                    Yes, admitted - apart from copying ruby files to the plugins folder I don't have much clue.
                    Also I have tried to export vectors from Inkscape to DXF format to import into SketchUp, but SU splats/crashes immediately. any experience with that? Maybe I have to perform a conversion before exporting... dunno much about Inkscape either.
                    alex
                    • TIGT Online
                      @shura said:
                      Dear Aerilius,
                      all I get is this:
                      alex
                      svg.rb:
                      This script allows to use Inkscape to create 2D images and to create Sketchup group(s) from the SVG File Inkscape has written.
                      The script requires rexml: You will find the files in a standard ruby environment: Copy the rexml Folder to your Sketchup Plugins Folder.
                      You will also need the forwardable.rb and set.rb from ruby in your Plugins Folder.
                      So you need to get ' Inkscape' AND have rexml AND forwardable.rb and set.rb... It'd be kind if the author of svg.rb posted at least some links if he wants you to try his tool πŸ˜’ even I'm confused πŸ˜•
                        A free Autotrace "online" πŸ˜‰
                        So you can use any Tif, JPG, PNP etc images and export as DXF for example (if you have always free Google Sketchup 6 πŸ˜‰
