    Rendering Stretched Textures
    15 Posts 3 Posters 1.4k Views 3 Watching
      Ben Ritter
      Hello everyone,
      I'd like to render some models where I've applied and stretched an image being used for texturing. Perhaps this is a question to be posted on the SU Podium forum because I'm trying to render in that application, but the texture does not render with the same look as in SketchUp. Is there something, within SU, that I'm doing wrong, or is this a problem with SU Podium only?
      Thanks. Ben
        d12dozr
        I'm not familiar with Podium so this is a guess, but did you try to make the texture unique before rendering?
        http://goo.gl/f7ooYh
          Ben Ritter
          Textures unique? I obviously didn't because I'm not familiar with how to do that.
            d12dozr
            Right click the texture and click "Make texture unique"
              Are we more accurately talking about distorted textures?
              I'm not familiar with Podium, but I used V-Ray, and I was looking into the matter of distorted textures on a thread of its own.
              In my experience:
              Stretched textures renders in all render engines.
              Skewed textures renders in all render engines.
              Distorted textures (non-parallelograms) are the only ones I've seen not to render properly in some engines.
                Ben Ritter
                Marcus, thanks for your help, but I don't have that option after "right-clicking" the texture.
                  Ben Ritter
                  ThomThom, I'm not sure I know the difference between stretched, skewed and distorted. I would say it's either strethched or distorted.
                  I applied the image as a texture, then took the pushpins and stretched it to fit the face. Is that distorted or stretched?
                  Thanks.
                      Ben Ritter
                      thomthom, thanks, I see what you mean. Yes, I've distorted the textures.
                      But why don't I see the option d12dozr is talking about?
                      Ben
                          Ben Ritter
                          Negative on "make unique texture". Is this an SU7 feature?
                            d12dozr
                            Yes, I believe so...I don't know what else you can try short of installing SU 7 free πŸ˜‰
                              Yes.
                                Ben Ritter
                                Thanks thomthom and marcus. I will try your suggestions in SU7.
                                Ben
                                  Ben Ritter
                                  That seems to do the trick. In one instance, I had to make it a unique texture, then re-apply and make unique again. Oh well, whatever works, correct?
                                  Thanks for your help.
