    Section Plane Visibility
    5 Posts 3 Posters 503 Views 3 Watching
    • R
      redinhawaii
      SU Section Cut issues.pdfGot an issue I need clarification on,
      How / where do I find my section cuts within a group, specifically when I have multiple section cuts?
      In the illustrated case I have two "active" section cuts, two inactive. One of the active section cuts does not actually cut, seems that visibility is for section plane only, not cut, but I cannot "find" which group they "reside" in. Or was it the fact that they were created in a specific group and are there fore part of that group and linked?
      • TIGT
        If the section-plane is part of a group and the section-planes are set to be visible you can double-click on the section-plane and it will open its container group for editing: to make it even clearer set view > component edit > hide rest of model so that during the edit only that group and its section-planes are seen... ❓
        • R
          redinhawaii
          Tried it, that did not seem to change anything.. the three section planes... still show up blue and not clear on how to ungroup them.
          an or where they are found...
          any insights most helpful
          aloha
          red
          • TIGT
            If you can edit the group containing the section-plane the select it and Edit>Cut. Exit the edit back into the model [or another group's edit] and Edit>Paste-in-Place the section-plane will move into another entities set ?
            • E
              ericschimel
              This video might help you, let it play all the way through and I think it will answer your questions....
              -Eric
              http://plugin.sketchthis.net
              Sketchup Kitchen Design Plugin
              Custom Models
