    [Plugin]Group in Component
    25 Posts 9 Posters 17.9k Views 9 Watching
      sahi
      The script creates a group component
      Menu Plugins >> Group in Component
      components.rb
      Edit: Changed title to contain tag '[Plugin']
      • Chris FullmerC Offline
        Hi Sahi, I'm not quite sure what you mean. It turns groups into components? Or changes components into groups? Or something entirely different?
        Chris
        All my Plugins I've written
          sahi
          Group changes in the components.
          If the group does something similar to the one component
            Looking at the code and I still don't understand what this does.
              sahi
              1.selection Group
              2. Translates into a component group
              3. It scans all the remaining groups
              4 If there are the same then replaces them with this component.
              • CadFatherC Offline
                CadFather
                guess it's like the one in thom's selection tools - turn groups in components.. amazing what a couple a semantic turn can do..
                  I'm not sure if it is quite the same. It does some comparisons of edge lengths...
                    If that is an update, could you update the first post please?
                      sahi
                      Yes.
                      Сreate an array of them, sort, compare. (Compare the array and not the length)
                      In the plugin still has bugs.
                      Here's a version of the plug
                      updated in first post
                        rv1974
                        @sahi
                        MGIMO finished? 🙂
                          sahi
                          @rv1974 said:
                          @sahi
                          MGIMO finished? 🙂
                          http://s.rimg.info/8515032bfe765a932cb54887d1f869d6.gif
                          • P Offline
                            putnik
                            sahi,
                            напиши по русски, что плагин делает, я переведу. не особо понятно.
                            http://keshas.info
                              sahi
                              @putnik said:
                              sahi,
                              Скрипт переводит группы в компоненты. одинаковые группы заменяет на один компонент.
                              Вот для примера файл: смотрим статистику
                              Pech_SU5.zip
                              Состоит из групп, размером 756 кб, групп 155
                              Выделяем все и применяем скрипт.
                              Размер файла уменьшается на 500 кб
                              PS: Скрипт ещё не закончен, ему не хватает точности, но все же довольно таки не плохо работает.
                                rv1974
                                чем он отличается от уже сушествуюшего?
                                  Any explanation what this most recent file is? Thanks!
                                    From Google Translate:
                                    The script takes the group into components. The same group replaces one component.
                                    Here's an example file: look at the statistics
                                    Pech_SU5.zip
                                    (290.92 KiB) Not downloaded yet
                                    Consists of a group size of 756 kb, 155 groups
                                    Select all and apply the script.
                                    File size reduced to 500 kb
                                    PS: The script is not finished yet, it lacks precision, but rather did not not work.
                                    • chriC Offline
                                      chri
                                      hi Sahi
                                      you have done a great job 👍 👍
                                      seems to work with SKECHUP 8 and 2013
                                      Doesn't work with SKETCHUP 6 2014 2015
                                      Thanks again
                                      Chri
                                      • G Offline
                                        glro
                                        @chri said:
                                        hi Sahi
                                        Thanks again
                                        Chri
                                        i wish i could get the same result on my computer
                                        i only get an error message
                                        • chriC Offline
                                          chri
                                          in english
                                          You will find here , my system and my plugin file if it can help you .
                                          en français
                                          Bonjour
                                          Trouves ci-joint des images de ma configuration et le fichier ruby correspondant a notre sujet .
                                          Salutations
                                          Chri
                                          components.rb
                                          • G Offline
                                            glro
                                            @chri said:
                                            in english
                                            en français
                                            Bonjour
                                            Salutations
                                            Chri
                                            Thank you !
                                            i don't know why, but with the file you put in line, i don't get the error message
                                            it worked also on my computer: the plugin makes components out of groups if they are square boxes
                                            From the test i made, the square boxes must have been made into a group and then duplicated, before the plugin is used; otherwise the plugin doesn't recognize them as identical and makes 2 different components
                                            it could be possible maybe to make it work for other types of groups; by checking the distance between the corners of the bounding box, for example
                                            i shall try
                                            • 1 / 2
