    Material on separate layer
    4 Posts 3 Posters 357 Views 3 Watching
      tspco
      Is it possible to apply a material to a face on its own layer?
      I have a situation where some of the materials I use, cause a slow down of my computer, when orbiting. Sometimes I decide to add or change an entity after I add materials to the model.
      SU make 2017, /Twilight Render Hobby
      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
        Materials do not exist individually and separately from faces (image entities do but that is a different thing). This means that you either display the face bearing the material or hide the face itself.
          You could turn on the Colour by layer if you like - then the material of objects are controlled by the layer material.
            tspco
            What I ended up doing was adding a new face to a group, by retracing the lines of the group. I ended up pulling the new face out a tiny bit to keep the new layer from "flaring" or reacting with the original face, when orbiting/moving it works for now.
