    Material on separate layer
    4 Posts 3 Posters 442 Views 3 Watching
    • T
      tspco
      Is it possible to apply a material to a face on its own layer?
      I have a situation where some of the materials I use, cause a slow down of my computer, when orbiting. Sometimes I decide to add or change an entity after I add materials to the model.
      SU make 2017, /Twilight Render Hobby
      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
      • GaieusG
        Materials do not exist individually and separately from faces (image entities do but that is a different thing). This means that you either display the face bearing the material or hide the face itself.
          You could turn on the Colour by layer if you like - then the material of objects are controlled by the layer material.
          • T
            tspco
            What I ended up doing was adding a new face to a group, by retracing the lines of the group. I ended up pulling the new face out a tiny bit to keep the new layer from "flaring" or reacting with the original face, when orbiting/moving it works for now.
