    Creating "Round" Edge
    8 Posts 4 Posters 829 Views 4 Watching
    • N Offline
      Newbie4
      Hello guys,
      I just downloaded and tried Sketchup 7. So far I am very impressed.
      I currently want to make a cube with round edges, I attached a screenshot. Now I want to close those open edges but I have no idea how to do that. I tried google and youtube but I probably have the wrong search query.
      Thanks in advance,
      Flo
        Fredo's 'Round_Corner' plugin should do it all with rounded corners - if that still fails or you have it already made with missing bits then try using my 'Extrusion_Toolset' (i.e its 'ExtrudeEdgesByRails', where you pick the profile and the melding-profile as the same curve at the start and end - the other two sides are the two rails).
        Another possible problem is if the object is too small and new faces would have edges <~1mm they don't get made by SUp/OpenGL - trick is to group your geometry, edit the group and select all, scale it up x10, do the stuff then scale down x0.1 - the faces are made and remain even when scaled down...
        • N Offline
          Newbie4
          Sorry for pestering, but do you have a link to the round corner plugin? Entering it in google shows some jQuery stuff and I can't find it here:
          Error 404 (Not Found)!!1
          (sketchup.google.com)
          Thanks so far,
          Flo
            remus
            Do a search in the plugins forum on here, or even just have a browse through the first few pages of the forum, i have a feeling its fairly close to the top.
              Please learn to use the forums search tool - top right...
              Or to the left above here for each forum...
              Entering 'Round Corner Fredo' returned lots of hits - the third one takes you to here [p17] http://forums.sketchucation.com/viewtopic.php?p=171721#p171721
              • N Offline
                Newbie4
                Yeah, thanks, I found it after I posted that thread and I couldn't delete it. Sorry for the inconvenience.
                  remus
                  No worries πŸ˜„
                  • Jean LemireJ Offline
                    Jean Lemire
                    Hi folks.
                    If you would like to learn the basic tools of SU first to appreciate the talent of Ruby scripts writer, see this SU file for ideas.
                    Dice.skp
