    Shapebender plugin
    7 Posts 4 Posters 769 Views 4 Watching
    • C
      catherine1
      doing final in college and just discovered this plug in which could be amazing for my curved ramps going up through building BUT it won't work for me!!
      It's great up to the point where i select straight line and curve then....nothing??
      HELP!! Please!
      Catherine
      • Chris FullmerC
        Hi Catherine, does it say anything in info bar in the bottom left corner of the SU window? Anything about 5% or something?
        If not, could you upload a test model where it is not working? Then I'll take a look at it, thanks!
        Chris
        All my Plugins I've written
          Put all inside the "positive quadrant" ! πŸ˜‰
          • C
            catherine1
            Hi Chris, very new at this and don't know how to upload a model!!
            There is no sign of 5% on menu bar.
            Wondering if I extracted all info from plugin. Seems like I did?
            Catherine
            • TIGT
              Do you have progressbar.rb in your Plugins folder ?
              Also Open Window > Ruby Console and see if there are any error messages when you run this tool.
              To upload a file click the 'Upload Attachment' tab below your 'Post a Reply' text pane, Click the 'Browse' button and find the file and select it, when it's listed click the 'Add the File' button... Once its added to your post, if desired you can click on its 'Place in Line' option in the Attachments list, and it'll be placed at the cursor position in your post text rather than simply linked at the end of the posts' text - this is useful for images etc, but this doesn't really matter with a simple skp or zip file etc.
              Before uploading make sure your skp is <~4Mb and also use the Model Info > Statistics > Purge Unused option, to make it as small as possible...
              Hope this helps... πŸ˜„
              • TIGT
                You might be missing progressbar.rb !
                You were told how to get it in the original download thread πŸ˜’ , you'd better find [Search 'progressbar'] and download it from here http://www.smustard.com/search/ [it's free] and then put it into your ../Plugins/ folder and restart SUp - see if it works now... β˜€
                  And the last version of the Component Spray by Didier Bur πŸ˜‰
