    Trouble making a 2x4 wood beam
    10 Posts 6 Posters 4.3k Views 6 Watching
    • S
      Superted
      Hi. I am playing around with SketchUp, and I'm currently trying to construct a bench for the yard. However, I'm having trouble filling in the sides of the diagonal beams to make them, well, complete. I hope you guys can help me with this. I just don't understand it:-) Have attached the file so you see what I mean:-P
      Arne
      Parkbenk.skp
      • D
        d12dozr
        Welcome to the forum Arne,
        There are many ways to do this, however I would just make a plain 2x4 componentlonger than you need, place it accurately using Sketchup's inferencing and the Rotate tool, then double-click the component to edit it and trace along the intersections of the adjoining lumber. Just delete the extra and you will have a perfectly fitting board!
        Does that help?
        http://goo.gl/f7ooYh
        • D
          dedmin
          The main problem - make every part component first to separate pieces as in reality.
          • D
            d12dozr
            BTW, the reason you make it a component is so you only draw the board once, then just copy it to the other side. Actually any time you have 2 or more identical objects in a model you should make the first one into a component and copy it, that way if you make a change to one, all of the copies will update as well. πŸ˜‰
            Dedmin beat me πŸ˜„
            • S
              Superted
              Thanks for the incredibly prompt response guys:-) I will try this out at once:-)
              Thanks again:-)
              Arne
              • D
                dylan
                Good info posted already.
                Arne if you look at your model I uploaded again, I created 5 components. That is all you need to model for this and just fit them in place.
                Parkbenk 2.skp
                http://dmdarchitecture.co.uk/
                • TIGT
                  Recommend you split it into components as suggested.
                  Also the raking rails were not drawn with coplanar edges so they can't have faces.
                  As suggested make a beam orthogonally that's a bit longer than you need, group it and move / rotate into place, edit it and select all, then intersect with model [right-click] to make cut-lines. If you toggle View > Component Edit > Hide Rest of Model. you can see what you're doing... Erase the unwanted bits.
                  If you make a component rail rather than a group you can simply copy it into the other orientation and if you edit one the other changes automatically... πŸ€“Capture.PNG
                  • S
                    Superted
                    Thank you so much for all the answers:-)It really helped me.
                    I redid the entire model using components as you guys suggested, and it was so much easier I feel like an idiot doing it the way I did the first time:-P
                    Thanks again
                    Arne
                    Have attached the result.
                    Parkbenkrev1.skp
                    • GaieusG
                      Nice table, Arne. I made a quick render (and yes, I know the composition is not a great one at all)
                      πŸ˜’
                      Got the grill from the Warehouse for it.
                      • S
                        Superted
                        Cool rendering:-) When I see it like that I will certainly build it:-) Thanks for all the help, and the positive feedback:-)
                        Arne
