    Stair
    7 Posts 2 Posters 555 Views 2 Watching
    • F Offline
      ferrosoa
      Hi, i have problem with modelling this stair. Do you have any idea?
        Try this http://forums.sketchucation.com/viewtopic.php?p=158602#p158602
        I know it's based on underlaying an image but you can adapt it to a 2D plan of the stairs too... ๐Ÿ˜„
        You could also look at these http://forums.sketchucation.com/viewtopic.php?p=160622#p160622 ๐Ÿ˜ฎ
        • F Offline
          ferrosoa
          thx i try it ... correction: my problem is with bottom part, curve surface ๐Ÿ˜‰
            The soffit part is explained in the end section of my stair tutorial skp - copy the treads down select edges move 'up' with alt for auto-folding etc ๐Ÿ˜•
            • F Offline
              ferrosoa
              Its work, but soffit has a few faces. Must wait for Curviloft from Fredo (amazing thing). Its what i need
                If you make the top and bottom 'tread' lines into 'curves' with ' weld.rb' [divide the 1 edge into 2 or more pieces first], and also make 'curves' from the two side 'stringers', then you can use my ExtrudeEdgesByRails [part of the Extrusion Toolset] - then you'd pick the bottom 'tread' as the 'profile', then the stringers as the two 'rails' and finally the the top 'tread' as the 'melding-profile'... It should form a mesh face to suit... Here's a quick example...Capture.PNG
                • F Offline
                  ferrosoa
                  @tig said:
                  If you make the top and bottom 'tread' lines into 'curves' with ' weld.rb' [divide the 1 edge into 2 or more pieces first], and also make 'curves' from the two side 'stringers', then you can use my ExtrudeEdgesByRails [part of the Extrusion Toolset] - then you'd pick the bottom 'tread' as the 'profile', then the stringers as the two 'rails' and finally the the top 'tread' as the 'melding-profile'... It should form a mesh face to suit... Here's a quick example...[attachment=1:3wyvaxf0]<!-- ia1 -->Capture.PNG<!-- ia1 -->[/attachment:3wyvaxf0]
                  thank you tigger, ill try it ๐Ÿ‘
                  here is sample
