    Need bezier curves
    3 Posts 3 Posters 401 Views 3 Watching
      tbender54
      Hi all,
      I downloaded the latest v of bezier and BZarc by Fredo6.. Everything went fine as far as putting the files in but when I open the Sketchup preferences I don't get a bezier extension to turn on. Plz help if you can
      TB
        Post in the Plugin's topic, or PM Fredo...
          August
          Hi tbender,
          @tbender54 said:
          ... Everything went fine as far as putting the files in but when I open the Sketchup preferences I don't get a bezier extension to turn on.
          You didn't post in the Bezier Plugin topic. Did you get it solved?
          After installing the files, you have to restart SU because SU only reads what's in the Plugins directory when it starts up -- that includes adding the option to the Preferences > Extensions menu.
          It's also possible to have the Bezier Extension installed but have the toolbar turned off. Go to View > Toolbars to check.
          I hope this helps,
          August
          β€œAn idea, like a ghost, must be spoken to a little before it will explain itself.”
          [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
