    [REQ] label points with same X,Y Coordinates -pointcloud aid
    6 Posts 3 Posters 1.4k Views 3 Watching
    • halroachH Offline
      halroach
      Using points_cloud_triangulation.rb
      In some cases there are whole areas that aren't triangulated, or areas that the triangulation is overlapping. (see images)
      following the error message in the console, I figured that the problem occurs when there are points that share a common X,Y coordinate (on a different Z).
      It is a tedious task to find these points throughout a large model. I was wondering if there might be a script to label points that share the same Z? something similar to labeling stray lines - in "stray lines.rb".
      Or if anybody knows how to write a script that would do that!?
      point cloud
      applying points_cloud_triangulation.rb
      points sharing same X,Y coordinates
      error message from points_cloud_triangulation.rb
      FlexTools - Super Quick Windows, Doors, Slats...
        Try this
        require 'sketchup.rb'
        def cpointseqxy()
          model=Sketchup.active_model
          ents=model.active_entities
          layers=model.layers
          tlayer=layers.add("cpointseqxy")
          sel=model.selection
          sela=sel.to_a
          sel.clear
          model.start_operation("cpointseqxy")
          cs=[]
          ca=[]
          sela.each{|e|
            cs<< e if e.class==Sketchup;;ConstructionPoint
            ca<< e if e.class==Sketchup;;ConstructionPoint
          th=[]
          ch=[]
          lh=[]
          ca.each{|c|
            cx=[]
            cs.each{|e|
              next if c.to_s == e.to_s
              if c.position.x == e.position.x and c.position.y == e.position.y
                cx<< e
                ch<< e
                t=ents.add_text(" =XY",e.position)
                th<< t
                l=ents.add_cline(c.position,e.position)
                lh<< l
              end#if
            cs=cs-cx
          th.each{|t|t.layer=tlayer}
          lh.each{|l|l.layer=tlayer}
          sel.add(th+ch+lh)
          model.commit_operation
        Copy + Paste the code into a file in the Plugins folder called cpointseqxy.rb.
        Restart SUp and select everything [only cpoints get processes anyway].
        In the Ruby Console type cpointseqxy and all cpoints with common X & Y values are highlighted and highlighted =XY text is added next to each of them, also a highlighted vertical cline is added between them. Note that the text and clines are also put onto a layer called 'cpointseqxy' - so you can isolate them or delete them more easily [by deleting the layer and its contents]... 🤓
        • Didier BurD Offline
          Didier Bur
          Correct. Delauney algorithm is a 2D triangulation process, sort of. Having 2 points at the same location (plan view) breaks it.
          Note: the "Points are not planar" error can also occur if 2 points are very very very close to each other. It is a Sketchup "add_face" method issue, IMHO.
          DB
          • halroachH Offline
            halroach
            Very nice TIG! You're the man!
            It works wonderfully! 😍
            Could you have the text that's added, with arrows just like in "straylines.rb". I think it would make it easier on the eyes to find the points. I've added one arrow to demonstrate the difference, see attached image.
            Thanks! really great!!
            plugin works like a charm + would look better with arrows
            • halroachH Offline
              halroach
              There is a way to overcome the problem of very close points not closing faces. scale the the model x10. add the faces, and then rescale by .1. It usually works.
              Thanks guys!
                Try this
                    def cpointseqxy()
                      layers=model.layers
                      sel=model.selection
                      sela=sel.to_a
                      sel.clear
                      vec=[10,10,10] ### change these values for arrow length
                      cs=[]
                      ca=[]
                      sela.each{|e|
                      th=[]
                      ch=[]
                      lh=[]
                      ca.each{|c|
                        cx=[]
                        cs.each{|e|
                            cx<< e
                            ch<< e
                            t=ents.add_text(" =XY",e.position,vec)
                            th<< t
                            lh<< l
                          end#if
                        cs=cs-cx
                      sel.add(th+ch+lh)
                This has arrows for the text: vec=[10,10,10] sets the arrows 'vector', adjust the value of it to change the leader location, length etc...
