    πŸ›£οΈ Road Profile Builder | Generate roads, curbs and pavements easily Download
    DWanimations First small VRay 1.48 project...
    20 Posts 15 Posters 1.2k Views 15 Watching
      dirkkkk
      Hi all here is my first (small) commercial project that I did whit the new Vray using:
      -Ambient occlusion
      -The new fur plug-in for SU
      -Using a new material to create the light effect on the lamps in the living room (a first try)
      C&C most welcome, hope you like it
      http://www.dwanimations.org/view 2.2small.png
      http://www.dwanimations.org/view 1.2small.png
      • StinkieS Offline
        Stinkie
        AA's pretty bad, other than that these are great. πŸ‘
          dirkkkk
          What do you mean with "AA"...?
            rcossoli
            AA: antialaising
            Edge smoothing
            THREEDIMENSIONSWEB dot COM
              dirkkkk
              aahh thanks, well maybe the AA is not looking so good Beconase this is a scaled down version 800x600 original size 1600x1200.. πŸ˜„
              • StinkieS Offline
                Stinkie
                Hm. Did you resample the image?
                • 7 Offline
                  7homuz
                  very nice! the fruits and small details are so crucial, great job!
                  • Bryan KB Offline
                    Very nice. When can I move in?
                      Aidus
                      Great renders. Very clean!
                      CPU: Intel Core i7 Extreme Edition 965
                      RAM: OCZ Gold DDR3 1600MHz 12Gb
                      Video: Asus Radeon HD4870 X2 2Gb
                      Mobo: Asus P6T Deluxe 1366 Intel X58
                        DzineTech
                        Nice images Dirk, though I have found some area's that I suggest you could improve.
                        1. Stair stringer timber material mapping is wrong and should run parallel with the pitch of stair.
                        2. The top surface of the timber unit in the top image (bottom left) looks odd and should be rotated 90 degree's
                        3. Your timber beams show a fixing (bolt & square plate) which you have shown timber. Shouldn't these be a metal?
                        4. Your ceiling is showing a fair bit of splotches, you need to up your Irradiance map HSph's and samples to clear it.
                          sketchnl
                          Whow 😲 , this is looking good very good. πŸ˜„
                          http://www.sketchimpressions.nl
                          • majidM Online
                            majid
                            these are really clean and brilliant renders, mate.
                            • F Offline
                              FoXar
                              This is great! Your works are very inspiring man, they have some sort of 'mood' in them πŸ˜„
                              • stefanqS Offline
                                stefanq
                                Dirk, fantastic images again! This mood it's your trade mark. Regarding anti-aliasing, I don't think you have an issue with it. It's just vray , sampling those bright pixels ( the problem appear just in bright area/surfaces, right?).
                                Be sure to check "clamp output" and "sub-pixel mapping". That should do the trick!
                                Cheers!
                                • StinkieS Offline
                                  Stinkie
                                  Ah! Forgot about that!
                                  • marked001M Offline
                                    marked001
                                    wow... aside from those few small small texturing fixes, these are awesome!! great work..
                                    http://www.revision21vis.com
                                    instagram: revi21on
                                    • CoreMaster110C Offline
                                      CoreMaster110
                                      WOW nice πŸ˜„ πŸ‘ πŸ‘ πŸ‘ looks realy cool.
                                        dirkkkk
                                        Hi All thanks your your great tips/compliments/critics...
                                        I appreciate it. I was fine tuning the render a bit.
                                        -changed some materials.
                                        -tried to remove the spots on the sealing.(used HSph. Subdivs 999) :S
                                        The carpet is done by the fur plugin and I have to say, if used correctly you can great a better effect than displacement.. but I am sting learning how to use it because is very hard for Vray to render it without crashing.
                                        the textures of for the beams are from: http://www.cgtextures.com/
                                        and the plant is from the 3Dwarehouse
                                        Also I did a test in PS to create a evening mood without rendering a new picture... just using PS, pleas let me know what you think..?
                                        For more work you can also look at our new Facebookpage πŸ˜„ http://www.facebook.com/pages/DWanimations/118030554885929
                                        http://www.dwanimations.org/view 1.21small.png
                                        http://www.dwanimations.org/view 1.21darksmall.png
                                        http://www.dwanimations.org/view 2.21small.png
                                        http://www.dwanimations.org/view 2.21darksmall.png
                                        • soloS Offline
                                          solo
                                          Those darker ones with lights on are absolutely phenomenal!!
                                          great work....as always.
                                          http://www.solos-art.com
                                          • F Offline
                                            fymoro
                                            Wow, I have no words, except fantastic works... πŸ‘
                                            http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
