    DWanimations First small VRay 1.48 project...
    20 Posts 15 Posters 1.8k Views 15 Watching
      dirkkkk
      What do you mean with "AA"...?
        rcossoli
        AA: antialaising
        Edge smoothing
        THREEDIMENSIONSWEB dot COM
          dirkkkk
          aahh thanks, well maybe the AA is not looking so good Beconase this is a scaled down version 800x600 original size 1600x1200.. πŸ˜„
          • StinkieS Offline
            Stinkie
            Hm. Did you resample the image?
            • 7 Offline
              7homuz
              very nice! the fruits and small details are so crucial, great job!
              • Bryan KB Offline
                Very nice. When can I move in?
                  Aidus
                  Great renders. Very clean!
                  CPU: Intel Core i7 Extreme Edition 965
                  RAM: OCZ Gold DDR3 1600MHz 12Gb
                  Video: Asus Radeon HD4870 X2 2Gb
                  Mobo: Asus P6T Deluxe 1366 Intel X58
                    DzineTech
                    Nice images Dirk, though I have found some area's that I suggest you could improve.
                    1. Stair stringer timber material mapping is wrong and should run parallel with the pitch of stair.
                    2. The top surface of the timber unit in the top image (bottom left) looks odd and should be rotated 90 degree's
                    3. Your timber beams show a fixing (bolt & square plate) which you have shown timber. Shouldn't these be a metal?
                    4. Your ceiling is showing a fair bit of splotches, you need to up your Irradiance map HSph's and samples to clear it.
                      sketchnl
                      Whow 😲 , this is looking good very good. πŸ˜„
                      http://www.sketchimpressions.nl
                      • majidM Offline
                        majid
                        these are really clean and brilliant renders, mate.
                        • F Offline
                          FoXar
                          This is great! Your works are very inspiring man, they have some sort of 'mood' in them πŸ˜„
                          • stefanqS Offline
                            stefanq
                            Dirk, fantastic images again! This mood it's your trade mark. Regarding anti-aliasing, I don't think you have an issue with it. It's just vray , sampling those bright pixels ( the problem appear just in bright area/surfaces, right?).
                            Be sure to check "clamp output" and "sub-pixel mapping". That should do the trick!
                            Cheers!
                            • StinkieS Offline
                              Stinkie
                              Ah! Forgot about that!
                              • marked001M Offline
                                marked001
                                wow... aside from those few small small texturing fixes, these are awesome!! great work..
                                http://www.revision21vis.com
                                instagram: revi21on
                                • CoreMaster110C Offline
                                  CoreMaster110
                                  WOW nice πŸ˜„ πŸ‘ πŸ‘ πŸ‘ looks realy cool.
                                    dirkkkk
                                    Hi All thanks your your great tips/compliments/critics...
                                    I appreciate it. I was fine tuning the render a bit.
                                    -changed some materials.
                                    -tried to remove the spots on the sealing.(used HSph. Subdivs 999) :S
                                    The carpet is done by the fur plugin and I have to say, if used correctly you can great a better effect than displacement.. but I am sting learning how to use it because is very hard for Vray to render it without crashing.
                                    the textures of for the beams are from: http://www.cgtextures.com/
                                    and the plant is from the 3Dwarehouse
                                    Also I did a test in PS to create a evening mood without rendering a new picture... just using PS, pleas let me know what you think..?
                                    For more work you can also look at our new Facebookpage πŸ˜„ http://www.facebook.com/pages/DWanimations/118030554885929
                                    http://www.dwanimations.org/view 1.21small.png
                                    http://www.dwanimations.org/view 1.21darksmall.png
                                    http://www.dwanimations.org/view 2.21small.png
                                    http://www.dwanimations.org/view 2.21darksmall.png
                                    • soloS Offline
                                      Those darker ones with lights on are absolutely phenomenal!!
                                      great work....as always.
                                      • F Offline
                                        fymoro
                                        Wow, I have no words, except fantastic works... πŸ‘
                                        http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
