    FACES AND SUBDIVISIONS DO NOT SHOW IN RENDER
    renderpluginsextensions
    4 Posts 4 Posters 680 Views 4 Watching
    • kaluK Offline
      kalu
      hI to all, me again, I like to show the divisions of sketchup faces, I cut planes and divide panels and when I render I just see all melted in one big mess..Any help beside PS work that I can tune up and show the lines?....
      Thanks...
      THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
      • soloS Offline
        solo
        Vray does not render lines, you can either offset it, overlay the line inage in PS or slightly push pull, but no way to render lines in Vray.
        http://www.solos-art.com
        • EarthMoverE Offline
          EarthMover
          You also use the Convert Lines to Cylinders plugin and make the radius value very small and set the sides to 4, or use the line style tool in TIG's 2D tools to give the line width.
          Content Creator at Skapeup
            I wish you would not use all caps titles for your posts.
