    [Plugin][$] Curviloft 2.0a - 31 Mar 24 (Loft & Skinning)
    1.3k Posts 299 Posters 2.8m Views 297 Watching
    • charly2008C Offline
      charly2008
      Hi Fredo,
      attached you wil have a similar model because the first one i have deleted. I selected each segment separately. Thanks again for your plugin, thanks for your efforts.
      Karl (Charly)
      Test1.zip
        charly2008
        The same shape with small modifications
          lapx
          Thanks Tig! I'll try it out 🎉
          • Didier BurD Offline
            Didier Bur
            Hi Fredo,
            I get a bugsplat EVERYTIME I try to "loft by spline", no matter the method used. Any possible conflict with other plugins ?
            F: J'ai un bugsplat directement après avoir cliqué l'icône, quelle que soit la méthode de sélection que j'utilise pour les faces, contours, chemins, etc. Est-ce qu'il y a à ta connaissance un conflit possible avec un autre plugin (ceux de TIG par exemple, qui font un job similaire ?).
            Je suis scotché, là...
            DB
            • fredo6F Offline
              fredo6
              @didier bur said:
              Hi Fredo,
              At what step do you get the bug splat: selection, preview, generation of geometry?
              Is it with any model?
              I don't think there are conflicts with other plugins, and anyway not TIG's ones, because I have them in active my environment.
              Fredo
                Didier Bur
                @Fredo6: at any time, either in a blank new model, or in a model with geometry in it.
                The bugsplat occurs as soon as I click on the icon, once I have selected contours or faces and the path (no problem with selection. 😲
                I'm considering to start with an empty Plugins folder (except curviloft of course 😄 ) to see what happens.
                DB
                • urgenU Offline
                  urgen
                  ...Oh, Fredo,thank you very much! 👍
                  --pupil forever...------
                    djorkaeff
                    Very good and promising plugin. Thank you for your effort and generosity!
                    • JClementsJ Offline
                      JClements
                      Hi Fredo:
                      Is there anyway, once the surface group is created, that it could store the Curviloft parameters used? That way the user, if they had not completed all the surfacing, could verify and reuse those settings at a later time.
                      Perhaps there could be an eyedropper that could "suck up" the values of an existing surface-group and paste them into the Curviloft dialog?
                      I have been doing a bit of testing using contours from CAD and comparing the results with the Sandbox tool. I was not able to reduce the total curviloft surfaces (triangles and quadrangles) between contour elevations compared to the triangulated surfaces sandbox creates BUT Curviloft places its surfaces where they SHOULD BE unlike Sandbox which places surfaces that "bridge" across vertices of the same elevation ...that is a big time saver.
                      • pep75P Offline
                        pep75
                        This is a brilliant Plug-In...Super. Fredo fantastic!!! This is just what SU needed, just that little extra spline modelling tool. And for free! Better then the Booltools where you'll have to pay for and works 25% of the time...
                        Fredo you're my hero!
                          @pep75 said:
                          This is a brilliant Plug-In... And for free! ...
                          Please remember that although many of the scripters, like Fredo, do publish their tools freely, there is often a PayPal 'Donation' available - so you can give Fredo a little something, if you think he's worth it [which he is!] - I'm sure he won't object... 😉
                            autarchos
                            Hi Fredo -
                            I am having the same problem as Didier with bugsplats. I am able to make geometry selections, but the moment I attempt a loft by spline, SU crashes.
                            This occurs only on PC for me - the plugin works fine on Mac (both platforms have the latest version of SU)
                            • bazB Offline
                              baz
                              had a good play with loft by spline today...
                              ...no probs.
                              its looking abfab. thanks fredo.
                              ba
                              win7, (for my sins 😞 ). pent4. 3ghz. 3gb ram. nvidea 6600
                                Didier Bur
                                Hi Fredo6,
                                I finally got it to start without a bugsplat. Select edges, spline, and here is the error message:
                                Error: #<NoMethodError: undefined method -' for nil:NilClass> C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftSpline.rb:953:in spline_matrix_match_point'
                                C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftSpline.rb:930:in spline_matrix_column' C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftSpline.rb:927:in each'
                                C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftSpline.rb:927:in spline_matrix_column' C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftSpline.rb:646:in spline_matrix_analyze'
                                C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftSpline.rb:645:in each' C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftSpline.rb:645:in spline_matrix_analyze'
                                C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftSpline.rb:234:in spline_junction_construct' C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftAlgo.rb:1371:in junction_construct'
                                C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftAlgo.rb:415:in link_construct_all' C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftAlgo.rb:415:in each'
                                C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftAlgo.rb:415:in link_construct_all' C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftAlgo.rb:404:in link_calculate_all'
                                C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftAlgo.rb:377:in prepare_all' C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftAlgo.rb:368:in proceed'
                                C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftTool.rb:590:in transition_to_loft' C:/Program Files/Google/Google SketchUp 7/Plugins/CURVILOFT_Dir_10/CurviloftTool.rb:575:in notify_edge_picked'
                                C:/Program Files/Google/Google SketchUp 7/Plugins/LIBFREDO6_Dir_35/Lib6EdgePicker.rb:356:in call' C:/Program Files/Google/Google SketchUp 7/Plugins/LIBFREDO6_Dir_35/Lib6EdgePicker.rb:356:in notify_action'
                                C:/Program Files/Google/Google SketchUp 7/Plugins/LIBFREDO6_Dir_35/Lib6EdgePicker.rb:1214:in `click_outside'
                                Hope this helps you to debug somewhat
                                DB
                                • fredo6F Offline
                                  fredo6
                                  @didier bur said:
                                  Hi Fredo6,
                                  I located the problem, but it must depend on the model somehow (most likely the orientation of curves).
                                  I'll put a protection (or an error message) to avoid the bugsplat anyway and will republish.
                                  Fredo
                                    charly2008
                                    Hi Fredo,
                                    your plugin is a miracle. Could be a must for historical models.
                                    Karl
                                    • OxerO Offline
                                      Oxer
                                      Hi Fredo6,
                                      The plugin is fantastic, i'm modeling a XIV Century Church and it has a lot of organic details, your plugin will help me to finish it.
                                      I know that the plugin is a beta phase but i find a conflict with other plugin 'set.rb' requested for svg.rb (to import svg files to sketchup), it's a minor problem for me but i say it for inform to other users if they find that the plugin does not work and they have installed this plugin. (I work on Mac)
                                      Thanks for all your plugins!! 👍
                                      Bye!
                                      [http://www.oxervision.blogspot.com/(http://www.oxervision.blogspot.com/)]
                                      • brookefoxB Offline
                                        brookefox
                                        Here's a modest working use of the tool, much as exampled: to create a square to round transition, in this case for building gutter work.
                                        I hope folks will post more.
                                        ~ Brooke
                                        • fredo6F Offline
                                          fredo6
                                          @oxer said:
                                          Hi Fredo6,
                                          Bye!
                                          Where can I find this plugin svg and set.rb? I'd like to see where the conflict comes from.
                                          Fredo
                                            JClements
                                            Fredo:
                                            Is there a possibility that coplanar surfaces would be created with Curviloft?
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 65
                                            • 66
                                            • 7 / 66
