    [Plugin][$] Curviloft 2.0a - 31 Mar 24 (Loft & Skinning)
    1.3k Posts 300 Posters 3.3m Views 298 Watching
    • fredo6F
      fredo6
      @alomphega said:
      May I suggest/ask you to make a complete and ultimate step by step here to guide the newcomers of your crazy Curviloft tool ?
      I certainly need to improve on the tutorial and provide documentation (that's why the plugin is still in Beta).
      For now, I suggest users have a look at the videos and try to get inspiration from the Quick start section of the main post.
      Fredo
      • AlomphegaA
        Alomphega
        Ok, thanks Fredo6 for your work and your answer.
        So I've done a try and to help you a bit I post here a little "newcomer oriented installation resume" :
        To install Curviloft as a beginner we just have to close SketchUp and to download these 2 files :
        LibFredo6 4.2a – 16 Sep 11 -> http://forums.sketchucation.com/download/file.php?id=74965
        Curviloft 1.2b – 26 Sep 11 -> http://forums.sketchucation.com/download/file.php?id=75416
        Then we just have to open these zip files, to take all that is inside, and to put it into the "Plugins" folder of the Google SketchUp installation without changing anything, nor names, nor hierarchy.
        (for instance under Windows 7 64bits if you have done a standard installation copy all that is in the zip files into the "C:\Program Files (x86)\Google\Google SketchUp 8\Plugins" directory)
        After that we can open SketchUp, that's all.
        Of course after a quick try I encourage to re-check this entire topic from beginning to see tutorials, to install within an additional directory, to download manuals and so on...
        Best Regards,
        Guy
        Guy Capra, http://www.nauticaerium.com
        Non je ne suis pas un "Géo Trouvetou", juste un "Géo... Zéchercher" ! ;)
        • jeff hammondJ
          jeff hammond
          Curviloft 1.2a – 21 Sep 11[/color]: Include the generation of Pseudo-quads allowing the usage of the new QuafFaceTools by Thomthom. Also, it avoids generation of empty group if there is a problem.
          nice! 👍 👍
          dotdotdot
          • R
            redlerred7
            I believe an update is in schedule.
            A new version of Quad-face tools was released and now has a different definition on the so called "pseudo-quad".
            • thomthomT
              Fredo is aware of it. Until it's updated, use the Convert Sandbox Quads to QuadFace Quads function in QuadFace Tools.
              Apologies for the inconvenience - but I had to do it in order to address a critical issue. 😞
              • fredo6F
                fredo6
                NEW RELEASE: Curviloft 1.2c - 15 Nov 11
                IMPORTANT: you need to install LibFredo6 4.2 (or higher). With this version of LibFredo6, the ZLoader__Curviloft.rb is no longer necessary.
                This release includes more options for the generation of pseudo-quads for usage by the new QuadFaceTools by Thomthom.
                Options are available in the Default Parameters dialog box
                By default, pseudo-quads are generated with:
                • Borders: Soft + Smooth (+ Cast Shadows)
                • Diagonals: Soft + Smooth + NO Cast Shadows
                This allows to have a nice-looking surface, while being compliant with all functionality of Thomthom quads tool (which is already upgraded with the above definitions)
                See main post for download
                Fredo
                • thomthomT
                  Thanks Fredo for the quick update. I love using Curviloft to produce quads.
                  Maybe we should produce some nice example models the demonstrate Curviloft and QuadFace Tools. ...maybe some of the users already got some..? Anyone?
                  • D
                    driven
                    @fredo,
                    it's not showing in 'check for updates'... yet
                    @Thomas,
                    when, 'check for update' takes you to your bitbucket site,
                    it's not the download page and the link [to the download page] is quite discrete.
                    It catches me out every time I go there, could it be more obvious?
                    john
                    • thomthomT
                      My bad. I'll update the link.
                      • L
                        lapx
                        I'm trying to map a texture on this shape. I must admit I'm totally at a loss understanding the uv and quad rubies.
                        I'm sure I'm missing out on some powerful tools if i fail to understand these.
                        Need some help in explaining how these would work in this application.
                        Thanks!
                        UVTEST.skp
                        • thomthomT
                          If you want to map that with QuadFace Tools you need to generate the mesh as a set of quads.
                          I assume you use Curviloft to create the mesh, you need to explicitly tell it to generate quads.
                          • A
                            aea
                            hello
                            I tried to install Curviloft but does not work. When you install the 4.2 LibFredo6 disappear Hoverselect and Roundcorner that can not be used.
                            I attached ... please
                            • L
                              lapx
                              Thanks Tom,
                              Yes I did use curviloft and joint pushpull after skinning to get thickness. Will the joint pushpull operation destroy the quadfaces?
                              I'll try it.
                              Thanks again Tom! You are amazing!
                              • thomthomT
                                I believe so...
                                • L
                                  lapx
                                  Tom,
                                  I just tried it with your instruction and still could not get it to work. I got it to work on a flat surface.
                                  Can you try it from the model that I uploaded? The rails are still in the model. It ask for U direction and I get nothing when I try and define U V direction. There is no highlight.
                                  Thanks,
                                  • thomthomT
                                    @lapx said:
                                    Tom,
                                    Thanks,
                                    I made a mesh with Curviloft using the rails - made it generate quads and I had no problem mapping it. ( Note that is you have anything selected, the UV mapping tool will limit the mapping to the selected entities. So make sure to deselect unless you can't to map a local region. )
                                    As for the extruded surface, I ran Convert Triangulated Mesh to Quads on it, turned out it converted it quite well. (surprisingly as it has issues)
                                    But I had to select a local region in order to map it, because the sides of the mesh could not be mapped to a 2D grid.
                                    See the screenshot for what selection I made:
                                    I picked a center-ish edge and used the Grow Edge Loop so the selection ran the length of the mesh - before it folds around the sides. Then I used Edge Ring to ring loop around the whole mesh. Then I use Select Quads from Edges.
                                    UVTEST.skp
                                    • L
                                      lapx
                                      Like I said, You are amazing! I'll try it an let you know the results when i get to the office.
                                      Thanks once more and many thanks to come.
                                      • A
                                        aea
                                        my instal new sketchup 8 and works ☀
                                        • L
                                          lapx
                                          One step at a time. Here's my curvi loft skin with quads activated. I select the quads by triple clicking in SU. I hit UV map selected quads and nothing happens when I try to pick UV direction. 😞
                                          BTW, my pick button on your quad tools is not working. Might that be the problem?
                                          Is there a problem using Su native picking tools?
                                          Thanks Tom for your help,
                                          Lapx
                                          • thomthomT
                                            You do not need to select anything in this case. Since you map everything.
                                            Do you get any error messages in the Ruby Console?
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 65
                                            • 66
                                            • 29 / 66
