    [Plugin][$] Curviloft 2.0a - 31 Mar 24 (Loft & Skinning)
    1.3k Posts 300 Posters 3.3m Views 298 Watching
    • pep75P
      pep75
      Thanks Fredo! Brilliant update!! Thanks so much!!
      grtzzz
      Pep
      • olisheaO
        olishea
        this really is a different league of plugin!!
        something i've been wanting for a LONG time. how come you don't charge? its amazing
        oli
        • mariochaM
          mariocha
          Testing the beta, the skin command cannot complete this file, attached.
          EEbyrails does it well tought.
          No-skin.skp
          %(#008000)[Mario C.
          • TIGT
            Both work for me... but there are more facets in CurviLoft's result...Capture.PNG
            • mariochaM
              mariocha
              Thanks TIG,
              So I tried it on the PC side of my MAC, and it worked just fine.
              frustrated me 😒
              Strange, cause other curves were ok.
              %(#008000)[Mario C.
              • fredo6F
                fredo6
                Mariocha,
                I think I know what it is and why it is specific to Mac. I'll publish a fix soon with a new release.
                By the way, you can adjust the density of meshing by using the Interpoland OverSamplingboxes. If you deactivate both, then you get a mesh strictly built on the original contour vertices.
                Fredo
                • mariochaM
                  mariocha
                  A new relase ? Great !! πŸ‘ πŸ‘ πŸ‘
                  And Oversampling & Interpol will be so usefull for designing !
                  C'est vraiment super !
                  as I'm working on a tensile structure these days.
                  %(#008000)[Mario C.
                  • cmeedC
                    cmeed
                    help.
                    I see skinning videos posted within this thread but i can't get this shape to work. it seems so simple.....
                    I click contours, click space, i then repeat until all three lines are coloured and click the tick button or open space. i get a PLEASE WAIT then nothing happens.
                    Am I doing something wrong, is it Because i'm on a mac?
                    the last picture is tig's rails but i have to make a 4th rail for it to work.
                    • TIGT
                      Should work with the 3 curves in either Fredo's or mine. With EEbyRails Pick the curve as the profile then the 2 side rails and then re-pick the profile again as the melding-profile - it will end with a point and triangular faces opposite the profile's end, as desired...Capture.PNG
                      • cmeedC
                        cmeed
                        Thank you for your speedy reply. Tig your plugin is working great (i didn't know about going back to my first curve to make three curves work, cheers)
                        what i'm making is a field of 800 tents - the ones you can put up in 3 seconds. So i need a way of using the contours and keeping the the polys down.
                        see pic tent - I used the loft by spline to get this but its not that great, Skinning didn't work.
                        i wanted to used fredos to get the polys down.
                        • TIGT
                          Reduce the number of segments in the arcs for the profiles/rails for EEbyRails with Entity Info [before scaling or making a 'non-arc'] ?
                          • cmeedC
                            cmeed
                            Thank you Tig. damn ! i knew that.... mmmm
                            • fredo6F
                              fredo6
                              @cmeed said:
                              help.
                              COuld you please post your model so that I can have a look and see what is going wrong.
                              fredo
                              • cmeedC
                                cmeed
                                Here you go...Thanks for looking...
                                I am almost sure it will work for you. Its so simple a shape.
                                tent1.skp
                                • fredo6F
                                  fredo6
                                  This bug, specific to Mac, has been corrected, but I did not publish the fix yet (due to work on the Loft Along Path). I'll do soon.
                                  It was already mentioned by Mariocha (see http://forums.sketchucation.com/viewtopic.php?f=323&t=28586&start=210#p262564)
                                  Fredo
                                  • fredo6F
                                    fredo6
                                    By the way, I forgot to mention that, when Skinning shapes, you can swap rails and profiles, which may be useful when the surface to generate is made from 3 contours.
                                    Fredo
                                    • utilerU
                                      utiler
                                      Fredo, this tool is quite incredible! I just haven't had time to play with it yet but have been following with much interest!! You really have 'user operation' high on your list.
                                      Incredibly well done!!
                                      Just Curious...
                                      • fredo6F
                                        fredo6
                                        New Beta version of Curviloft 1.0c and LibFredo6 3.5c - 20 Aug 10
                                        see Main Post for download
                                        This is an interim version whose purpose is to fix some bugs signaled by users and to prepare a next release which will be more functional. Again, thanks to all users for their help and contribution.
                                        1. Skinning: Bug on Mac preventing to Skin even simple shapes. Thanks to Mariocha and to Cmeed for signaling
                                        2. Skinning: Pre-selection mode should work with more shapes. Thanks to Daniel S. for providing some good examples.
                                        3. Loft Along Path: Still not finished. At least I have tried to improve the single-contour mode (kind of Follow Me, but accepting contours even non perpendicualr to the rail).
                                          By the way, I noticed some differences with the native SU FollowMe tool.
                                          Fredo
                                          Thank You Fredo, great update πŸ‘
                                          • EarthMoverE
                                            EarthMover
                                            Awesome. Thanks Fredo!
                                            Content Creator at Skapeup
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 65
                                            • 66
                                            • 12 / 66
