    [REQ] Prefix Group/Component Names
    8 Posts 4 Posters 1.2k Views 4 Watching
    • C
      chrisik
      hello,
      is this possible: select several named group/components, e.g. group "A" and group "B", run the (wanted) ruby, enter a prefix e.g. "1_", and the group/components an renamed in "1_A" and "1_B" an so on.
      thanks in advance.
      chrisik
      • D
        dedmin
        http://forums.sketchucation.com/viewtopic.php?f=180&t=23617&p=200995&hilit=mass+rename#p200995
        • TIGT
          Thanks dedmin - I knew I'd seen it somewhere πŸ˜’
          I thought I had done something on this... 😳
          • thomthomT
            How about moving that into a fresh [plugin] thread?
            • C
              chrisik
              yes it works for components but not for groups.
              could the script be modified to work also for groups?
              chrisik
              • TIGT
                Here's a new version that renames selected instances' definitions and also groups, adding suffixes and/or prefixes (banding "prefix-"[,"-suffix"] >>> prefix-Compo[-suffix] - using "","-suffix" adds only a suffix): it now also lets you used wildcards in the 'prefix' either to wipe the name and give it an incrementing name (banding "*A-001" >>> A-001, A-002 etc), or to substitute text (banding "|CAT|Cat|"); a suffix can still be used in conjunction with wildcarded prefixes...bandingCompoNames.rb
                • C
                  chrisik
                  thank you TIG.
                  works fine. πŸ˜„
                  • D
                    dedmin
