    How do i print all I have drawn not only what I see onscren?
    3 Posts 3 Posters 287 Views 3 Watching
    • G Offline
      gastons.tiltins
      I can Zoom Extents to see all my project.
      Then i can either print or export it in 2D.
      Problem is it is too sall to see all details i need. It prints only stuff i see on screen.
      I want SketchUp to print it on bigger scale.
      How can i do it?
      Or export it to JPG but all project not only what i have on screen.
      I hope it is possible to understan what i mean? If i zoom to certain detail and have scale i want it will print or export only the prat that is on screen visible. But I want it to print or expor all drawing just in bigger size/scale (even parts i dont see on my screen).
      Please give me tip!
      Thanks!
        Use Scene tabs to remember various views that you like/want. You can then make jpegs or print any these as desired ❓
        After orbiting around the model simply click a tab and it will return to that view...
        • Chris FullmerC Offline
          Zoom extents, then export a jpeg. In the jpeg export dialog window, press the "Options" button. Then change the image resolution to something much higher than screeen resolution. SU does not support anything over 9999 pixels I think. And I will often get crashes when try to save anywhere over 8,000 pixels wide or tall if the model is complex. So always save before exporting a high resolution image.
          And turn OFF anti-alias. If you leave anti-alias turned on, then SU often struggles with images over 4,000-5,000 pixels.
          Chris
          All my Plugins I've written
