    Existing site grade export to Revit
    8 Posts 2 Posters 782 Views 2 Watching
    • D
      diesellam
      I received a sketchup file that has the existing grade with the Google map applied to it.
      I want to know what's the best file format and setting to export the grade into Revit.
      What I want to do is have the calculation of the volume of grade that's going to be excavacated for the new building.
      Thanks in advance.
      • TIGT
        'Revit' will take in all manner of data formats - including SKP...
        Note that you can calculate volumes inside Sketchup by using one of the the 'Volume' plugins - I'd recommend the earlier one [v1.8], which is a lot slower but more robust when used in this type of situation... Here's an old tutorial on doing 'cut+fill' calculations using it...Cut+Fill.skp
        • D
          diesellam
          Thanks for the tutorial.
          I still don't quite understand how this works. How do you cut the hole of the terrain with the footprint of the building.
          Where can you get the "volume" plugin?
          • TIGT
            The 'hole/banking' was done using the Sandbox Tool > Stamp with an offset for the sloping parts.
            Volume is readily found doing a forum Search [advanced with Author = TIG] returns several... many are for the v2 - v1.8 is here http://forums.sketchucation.com/viewtopic.php?f=180&t=3048&p=14555&hilit=Volume#p14555
            • D
              diesellam
              Is there a way I can email you the file and have you take a look at it?
              I can't upload the file in here because it's a 10mb file, thanks.
              My email is:
              diesellam[at]gmail.com
              Thanks once again.
              • TIGT
                I've removed the @ from your email address as a 'bot' might harvest it and you won't want any more spam πŸ˜’
                Try it yourself first - work on a simplified form first so you understand what's going on - I'm bogged down with work this week - sorry...
                You could try importing the SKP into Revit too... but there's a Revit forum for that πŸ˜•
                • D
                  diesellam
                  No problem. I'll give it a try.
                  Do you have this tutorial in a screencast or something that's video based?
                  • TIGT
                    It's a really old scene stepped tutorial - done in v5 of Sketchup !
                    Sorry...
