    [Plugin] Pivot Around Axis
    32 Posts 15 Posters 29.1k Views 15 Watching
      Have you installed "ThomThom's Menu" ? If you did - then the location is different than the default Tools menu.
        alfort
        I new to installing plug-ins to sketchup. I've installed your script into the plugins folder but nothing is showing up in the tools menu after restarting sketchup. I'm using SU 7.1.
        • jason_marantoJ Offline
          jason_maranto
          Thank-you -- fits a need I've had perfectly.
          Best,
          Jason.
          • xiombargX Offline
            xiombarg
            This is massively helpful for me. I wish I would have noticed it earlier.
            Cookie sent! 😄
            • halroachH Offline
              halroach
              @thomthom said:
              Yup. I added a couple of things today, like being able to rotate groups. And click on other instances to adjust another object without existing the tool. Will hook up the VCB shortly.
              Hi Thom,
              Nice plugin!
              I can't seem to be able to select other objects when in the tool.
              Also it works only after I've selected an object. If nothing is selected, and the tool is run, nothing much happens... maybe I'm missing something?
              Thanks!! Many Cookies!!!
              FlexTools - Super Quick Windows, Doors, Slats...
                What other objects are you trying to select? What type of entities?
                • halroachH Offline
                  halroach
                  components...
                    Hmm... that should work, after the tool is active it should be possible to click other components (in the same context though)
                    • halroachH Offline
                      halroach
                      I click to turn the tool on. I click on any component, and it just doesn't do anything. Only if I have a component pre-selected and then activate the tool it works. But then I am limited to playing around with only that component. I cannot select other components without exiting the tool, selecting, and then running it again...
                      Maybe it's cause I'm using sketchup 2015 and not 2016?
                        Shouldn't be any difference between SU2015 and SU2016. This extension was created years ago.
                        Can you video-capture what you do? Maybe share a model?
                        • halroachH Offline
                          halroach
                          See attached video:
                          pivot_around_axis_01.avi
                            Hm... I wasn't able to play that in WMP. What codec are you using?
                            • halroachH Offline
                              halroach
                              I must have messed up something with the video, here it is on youtube instead:
                              https://youtu.be/8T2krSYI8_w
                                Huh,... looks like this isn't implemented after all. I must be confusing it with another extension.
                                • micioneM Offline
                                  micione
                                  Strange. It works well for me in SU 2016
                                  • 2 / 2
