    Intersection of 2 sloped surfaces
    2 Posts 2 Posters 283 Views 2 Watching
    • C
      currang2
      I was hoping to find the intersection of 2 sloped surfaces (a 1:8 and a 2:1) by drawing two objects and rotating the 1:8 sloped object about the vertical axis so that one of its sloping sides snapped on to the 1:2 face.
      I cannot work out how to make the line snap to the surface. I can't seem to get a precise intersection.
      I can work around by working out the slope distance, and drawing a circle on the 1:2 face of that radius, etc, but that still only gives me an approximate solution becasue of the limited accuracy of the sketchup circles.
      Is there a way to make the accurate interesection by rotating one object on to the other?
      • TIGT
        I can't get my head around this - can you post an image or two...
        The Protractor tool makes guide-lines at exact angle [degrees or A:B].
        It's probably quite straightforward but can you show us some steps - start/end condition desired etc etc...
