    Properties to save between scenes
    12 Posts 5 Posters 802 Views 5 Watching
    • P Offline
      Pout
      Is it possible to add extra elements to be saved for each scene? Eg. entity.material
      If not, are there any plugins which export a movie from Sketchup without the use of the Sketchup animation function?
      Thx
        If you want to change materials across scenes you need to use layers to control the visibility of similar components that have different materials applied in the two scenes...
        • P Offline
          Pout
          Ok, but that's duplicating the entities, which i really want to avoid at all costs
            Sorry, but changing materials of one instance across scenes is not possible unless you make duplicates , then vary their materials and use layers in the scenes to control their visibility - it's just not a function of Sketchup !
              MartinRinehart
              Add my vote. Would really be nice to have a blue ball and a red ball without having two otherwise identical balls.
              Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
                RickW
                It MIGHT be possible using an observer. I've used Scene observers to trigger animation of objects (very rudimentary animation), so it might be possible to use them to (re)paint objects.
                RickW
                www.smustard.com
                • Chris FullmerC Offline
                  Dynamic components re-color objects. You can't do anything very detailed as far as texture placement, but you most certainly can use ruby to re-color objects without having to duplicate the object.
                  Making scenes rememeber the material attribute might work using Rick's idea, and it might not. But you could re-write your own scene manager that could remember color settings.
                  Would it be painful to write? Probably.
                  Chris
                  All my Plugins I've written
                  • P Offline
                    Pout
                    Using scene observers works like a charm to do it. BUT, and for me this is a big BUT, the scene observer has big disadvantages:
                    • does not fire when creating an animation
                    • does not fire in Layout
                    • is gone if you close and reopen a model
                    So, when i want to create a movie, i'll need to write a complete script which saves images along a path between two camera views and then look for some external library which can create a movie of all these images and using Layout is impossible
                    Maybe there is some plugin already available with some of this functions available
                      My camera recorder writes images to the disk to make a movie from. You can use mencoder, a command line driven movie encoder, to turn those images into a movie. Or imagemagick. I do not think anyone has put all that into a single script yet. Its on my list of things to do with my camera recorder script, I've just not quite gotten it done yet.
                      • P Offline
                        Pout
                        Chris,
                        Great plugin! Do you think it can be used like this:
                        1. get all camera settings of all scenes
                        2. create a path from one camera setting to the other
                        3. execute a rb function (already written) with camera viewpoint of first scene
                        4. capture the movement along the 1st path (like your script does)
                        5. upon arriving at the camera viewpoint of the second scene: execute a rb function
                        6. capture the movement along the 2nd path (like your script does)
                        7. upon arriving at the camera viewpoint of the third scene: execute a rb function
                        and so on
                        In the end: Write all that to images (like your script does)
                        • combine into movie (i'll check the mencoder to see how to fire this from ruby)
                          Yup, that is all definitely possible. Writing the images to disk is not all that hard. It would be quite easy to make a script that exports animation frames from scene to scene, and executes a ruby method at each scene.
                          Does onyone out there know how to re-creatae the exact flythrough path though? Is that what you are hoping to achieve Pout? I have not ever figured out how to do that, but I think it is possible because it seems like some of the renderers are able to re-create SU's camera paths.
                          Chris
                            Pages.show_frame_at
                            I think that answer's my own question. I would guess that is how the actualy flightpath created by SU is re-created. It would be easy then to export images from scenes - recreating the actual SU flightpath, and then compile those into a movie (presuming you get mencoder to cooperate).
                            Chris
