    Vray material doesn't get rendered
    renderpluginsextensions
    3 Posts 2 Posters 854 Views 2 Watching
      diesellam
      Now I don't know if this is a problem or not.
      I tried to apply the Vray glass blue material to the elements.
      They seem to be applied. But when I did a test rendering, the VRay buffer is all black, what's the reason of it?
      Thanks in advance. See the attached file.
      window glass-VRAY PROLBEM.skp
        You are rendering glass, 100% transparent diffuse in a completely black environment. You won't get anything but blackness then.
          diesellam
          You are right. Thanks for the tips.
