    [Plugin] Lattice Maker
    149 Posts 69 Posters 355.3k Views 68 Watching
    • utilerU Offline
      utiler
      @tig said:
      @dhonzie said:
      TIG, i really appreciate all your plugins.... THANK U!!!!! 😍 😍 😍
      can you or somebody upload a tutorial for this so that i could apply this to my school project???
      Thank u n advance...... 😄
      There are several examples in the thread[s]...
      There are some movie tutorials for various plugins in the pipeline, but I can't say when they might be going public...
      I really look forward to these video tuts too, TIG. Always good to see it in action from a pro!!!! 👍
      Just Curious...
        arjunmax09
        Is it possible to delete in one go the original linear path used for lattice making??
        when you fail at something....you haven't really failed...you've found one way the thing will not work out
          Lattice Maker does NOT leave a linear path - it uses the selected mesh faces to make the 'panes' so the 'path' is consumed ?
          EEbyRailsToLattice does leave the Profile and Rail Curves... BUT on completion asks if you want to delete them -on a Yes they go too ??
          Please explain yourself differently... 😕
            arjunmax09
            TIG...I've uploaded images to clear my question
              Ah! You mean 'coplanar' edges - not easy removed because of the inner face. Because the LatticeMaker is for 3D meshes to Lattices each 'pane' is made separately.
              I suggest you get my 'Latticeizer' - that is intended for 2D forms and it does remove the original center-lines if specified. You draw the form and group it, then 'Latticeize' it - you should then get the results you want without center-lines...
              • bagateloB Offline
                bagatelo
                TIG: Please note if is possible to solve my problem: http://forums.sketchucation.com/viewtopic.php?f=323&t=16599&p=316794#p316794
                  Bagatelo
                  I have replied in the other thread you linked to - I think perhaps you mean Latticeizer NOT LatticeMaker ?
                  • bagateloB Offline
                    bagatelo
                    I am sorry having traded the place where it I should respond.
                    Please note the presentation that I have made in the attached file. That's exactly what I need. In some cases, I do not use handles in aluminum bar. I use ordinary handles. So I do not pull over 3cm from top face to bottom. In some cases, I use different spaces for 0.5cm, as requested by the woodworker or architect that I work. Thank you for your attention.
                    WHAT I NEED SKT 7.skp
                    • N Offline
                      Niffler
                      Thank you, TIG for all you do.
                      Although you are in the UK, I still would like to wish you a wonderful Thanksgiving holiday and to all you "Sketchers" out there. I lift my pint of (alcohol-free) nog to you, mates.
                      Peace
                      • broomstickB Offline
                        broomstick
                        I am truly in love with this piece of code! 😄
                          monivanh
                          I need it, i want it.
                          Thank you
                            anciano
                            SOLVED
                            After more persistent searching of the forums, I have finally found the answer so please ignore my post below.
                            So simple..the rails and profiles must be identical to produce square "Holes" using Lattice Maker.
                            Sorry for not finding that before posting..
                            Hello..I have searched the forums but cannot find a solution to my blundering attempts to create this:-
                            http://nofrillspropertyspain.com/graf/Capture1.PNG
                            Using EEbyRails and following the instructions (also have tried every combination of those)and then Lattice Maker, the result i always get id this:-
                            http://nofrillspropertyspain.com/graf/tri.jpg
                            No matter what I try, I cannot create the "Square" holes, only triangular ones.
                            If I remove the triangular lines prior to using Lattice Maker, the faces disappear making Lattice Maker not function.
                            Any help would be greatly appreciated ..
                            Thanks..
                            • pjbazelP Offline
                              pjbazel
                              TIG I have a request for this fantastic tool.
                              I have been using lattice maker on vonoroi tessellations (as you know, thanks again for the help), and since they have irregular shapes the offsets produce crossing edges in some cases.
                              I have noticed when using Fredo's tools on surface that offsets can be 'simplified' to eliminate the crossing edges. Is there any chance that you could incorporate this feature into lattice maker? That would be fantastic.
                              Thanks again,
                                Maybe you can use Clean Up by Thomthom ?
                                • pjbazelP Offline
                                  pjbazel
                                  That could be one option, but, I suspect that won't work.
                                  The offsets edges produced by lattice maker do not intersect one another when they cross. For some reason you have to tell SU to intersect to break the edges at the crossing. This generates a additional face, which must then be intersected with the edges to form the 'pane'.
                                  This really creates a lot of work. And though I would love to use lattice maker, I found it was faster and cleaner to use ToS offset on each cell, before JPP-ing. However, if lattice maker had a simplify offset feature I would have saved a ton of time.
                                  Do you think clean up would work for that? I haven't used it before.
                                    Can you post a 3D SU example model of your Voronoï problem of intersection ?
                                    (save as V6)
                                    • pjbazelP Offline
                                      pjbazel
                                      (save as V6)
                                      Sure, I will post it this weekend. Just at work now 😄
                                      • pjbazelP Offline
                                        pjbazel
                                        Pilou,
                                        Here is an example of the problem I was describing above. I made notes on the model, so you should see exactly where the issue is.
                                        If you think there is a quick way to fix this that would be great. I have never used cleanup, so if you find a way to fix the offset & intersect problem with that plugin please tell me.
                                        Thanks for helping with this.
                                        Example of problem PB_v6.skp
                                          As Pilou explained...
                                          You have one very tiny edge - resulting in the unframed section, when Sketchup fails to process its all but coincident vertices as separate points in space - a known tolerance issue with some tools like INtersect, FollowMe etc. That rogue edge is only 0.00874214349270001" long !
                                          There are also several edges shorter than the frame width.
                                          When Sketchup does an 'offset' if one of the edges is shorter than the offset distance you get a 'bow-tie'. Because LatticeMaker uses the same principle that's what you get if you try to use a face that has a short edge.
                                          To see this use the Offset tool on a face with a short edges, with the 'frame-width' and you'll get a bow-tie...
                                          It's easy fixed, using the Move tool on vertices to make these edges longer, or to combine two all-but-coincident vertices into one, so that the edge vanishes.
                                          The attached is a mesh made using adjusted bits to avoid 'bow-ties'.
                                          Incidentally, your mesh is facing down so the Lattice will be made upside down, unless your Reverse the faces - as in my example.Capture.PNG
                                          PS: I do have an unpublished SmartOffset tool that avoids the bow-tie issue with all offsetting...
                                            Thx for the V6! 😉
                                            Edit your Style for avoid bold lines and extremities!
                                            ANd more easy for see tiny segments! 💭
                                            (if you love it, you can re put them at the end of the session 😉
                                            Look in mega zoom where you have problem on the original!
                                            It's normal at some few places on the original result you have
                                            In fact just in one place ! ☀
                                            So you must first collapse all these crossing Lines / vertices and all will work like a charm! 😄
                                            You have also a cool one Multiface offset by Remus for make like lattices or some tricky things 😉
                                            http://forums.sketchucation.com/download/file.php?id=87095
                                            • 6
                                            • 7
                                            • 8
                                            • 4 / 8
