🤑 SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Plugin to export file google skecthup to XML format
8 Posts 4 Posters 7.4k Views 4 Watching
  • H Offline
    henda
    I need plugin to export google sketchup file to XML format appropriate to a data of other software
      What is wrong with the built-in xml type exporters like .dae ? Have you tried making one then changing the file's suffix to suit and using one with this 'other app' ?
      • H Offline
        henda
        You mean export to collada files?
        But it not in format approprite and i need to convert it
        can I use script ruby to convert it?
        I'd seen also su2kt it convert to XML file
        I need to export information like size , position materiel ...
        • N Offline
          notareal
          Collada defines XML schema. http://www.collada.org/2005/11/COLLADASchema/ So .dae is .xml as much as SU2KT exports .xml or maybe even more.
          Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
            A Collada 'dae' file has most of that info in it.
            Perhaps if you export your .skp to .dae using Ruby's export() and then rename the file and use Ruby file/text manipulation on it so it then suits what you want, that might be the easier way... 😕
            • H Offline
              henda
              So you think that the easier way is to convert
              to collada and after i should use ruby script to
              manipulate it?
                Assuming the format is quite similar - do you have an example of the format you are aiming for ?
                  Dig around this forum also. I think someone recently detailed in the developers forum how they got an xml writer hooked up through ruby so they can write xml files easily.
                  All my Plugins I've written
