    Plugin to export file google skecthup to XML format
    8 Posts 4 Posters 7.7k Views 4 Watching
    • H Offline
      henda
      I need plugin to export google sketchup file to XML format appropriate to a data of other software
        What is wrong with the built-in xml type exporters like .dae ? Have you tried making one then changing the file's suffix to suit and using one with this 'other app' ?
        • H Offline
          henda
          You mean export to collada files?
          But it not in format approprite and i need to convert it
          can I use script ruby to convert it?
          I'd seen also su2kt it convert to XML file
          I need to export information like size , position materiel ...
          • N Offline
            notareal
            Collada defines XML schema. http://www.collada.org/2005/11/COLLADASchema/ So .dae is .xml as much as SU2KT exports .xml or maybe even more.
            Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
              A Collada 'dae' file has most of that info in it.
              Perhaps if you export your .skp to .dae using Ruby's export() and then rename the file and use Ruby file/text manipulation on it so it then suits what you want, that might be the easier way... 😕
              • H Offline
                henda
                So you think that the easier way is to convert
                to collada and after i should use ruby script to
                manipulate it?
                  Assuming the format is quite similar - do you have an example of the format you are aiming for ?
                  • Chris FullmerC Offline
                    Dig around this forum also. I think someone recently detailed in the developers forum how they got an xml writer hooked up through ruby so they can write xml files easily.
