    [Plugin] VCB Calc v1.0 - 10 May 2010
    6 Posts 5 Posters 6.4k Views 5 Watching
      max-cx
      VCB Calc is a tool that computes the value of simple arithmetic expressions entered in the VCB. You can download it from http://www.drawmetal.com/download-vcb-calc. Instructions on how to use the tool are available here: http://www.drawmetal.com/use-vcb-calc
      The major features of the tool are:
      • Adds, subtracts, multiplies, divides and raises to a power.
      • Understands length, area and volume and their relationships.
      • Works with all standard SU units of measure (" ' mm cm m).
      • Click on an edge or a face in a model to use it's dimension in a calculation.
      • Uses the Ruby Console as a virtual "paper tape".
      • Observes format preferences on the Units tab of the Model Info window and displays results in multiple formats.
      • Accepts international decimal separators.
      • French version available.
      • Stores results in user-defined variables (named memories) [largely a Mac only feature].
      For example, entering 3" * 2 / 25.4mm = in the VCB yields the result 6 in the VCB. Entering 50"2 / 10" = yields the result 5". Entering 10"=mm yields the result 254mm.
      As an example of creating user-defined variables, suppose we wanted to divide 5 square meters by 10 centimeters and store the result in a variable named a. This can be accomplished by entering 5m2/10cm=a in the VCB. At least this is possible on a Mac, but not on a PC.
      The reason is that SU intercepts keyboard shortcuts differently between Mac's and PC's. On a Mac, only the first character of an expression entered in the VCB is subject to being interpreted as a shortcut. On a PC, the "a" at the end of the expression 5m2/10cm=a is seen as the keyboard shortcut for the Arc tool.
      Clearly, this limitation makes the tool a lot less useful/interesting on a PC than on a Mac. It makes it impossible on a PC to evaluate something like a + b = c.
      Many thanks to Gaieus, thomthom, TIG, and Jim for their insights and suggestions. Also, several beta users provided very valuable comments and feedback.
      Terry
        Slimdog
        WOW thats great Terry.
        I was just using my desktop mac calculator last night because I dont have a real calculator handy. It was painful.
        Steve
          Some people ask for that here πŸ˜‰
          • CadFatherC Offline
            CadFather
            Nice one Terry - probably the only time i wish i had a mac.. 😲
            Cheers!
            • X Offline
              xrok1
              Cheers!
              why do you say that? is it for mac only?
              β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                CadFather
                oh no, but it has more features on mac - variables etc
