    [Tutorial > Plugin] ToolsOnSurface
    4 Posts 4 Posters 17.0k Views 4 Watching
    • fredo6F
      fredo6
      This thread will be used to publish some tutorials on the Plugin ToolsOnSurface.
      See main post and download source at http://forums.sketchucation.com/viewtopic.php?f=323&t=11212#p76625
      1) Drawing shapes 'without' a surface: Although TOS is designed to draw geometry over curved surfaces, it has the capability to also draw without, with 2 situations where there is no surface:
      1. Draw perpendicular to edges
      2. select the default plane when shapes are drawn in the 'empty' space.
      This small video illustrates the feature:
      [flash=425,344:1fhfrtag]http://www.youtube.com/v/iYl2_inxxcg&hl[/flash:1fhfrtag]
      2) FreeHand with and without Surface: TOS includes a Freehand tool allowing to capture contours on a surface (ans also without a surface). Typically, it can be used to draw a contour from a photo or texture which is applied to a surface.
      FreeHandOnSurface provides 2 features that can be freely combined during a capture:
      1. Disabling or enabling Sketchup inferenceswhen drawing
      2. Point & Clickfor each point captured or Click & Moveto capture points with a configurable samplingin pixel.
      [flash=425,344:1fhfrtag]http://www.youtube.com/v/mdqsYAbUfTE&hl[/flash:1fhfrtag]
      • N
        notareal
        Thanks! Drawing shapes 'without' a surface - I had missed that feature.
        • D
          dylan
          Really like the feature of being able to draw shapes perpendicular to edges.
          http://dmdarchitecture.co.uk/
          • irwanwrI
            irwanwr
            how to draw those shapes along the path?
