    Circle segments
    3 Posts 2 Posters 489 Views 2 Watching
    • quimQ
      quim
      hi all
      i have a problem with arc and circle segments. i generally set the segment to 150 while i use sketchup which gives me a smooth arc or circle. However if i import a template at a later stage from autocad or copy a round object from a previous sketchup model it appears with less segments and flat sided. can someone give me some pointers please ????????????????
      WEBSITE http://www.q-prodesigns.co.za
      • TIGT
        The default import for arcs is always with a small segment count.
        You can adjust unconnected arcs' segments in 'Entity Info' - if there are lots there's my script http://forums.sketchucation.com/viewtopic.php?p=158903#p158903
        • quimQ
          quim
          thanks a stack tig
          no more redrawing arcs and circle for me πŸ˜„
