    OMG! fur plugin is AMAZING!
    168 Posts 44 Posters 74.4k Views 44 Watching
    • FrederikF Offline
      Frederik
      @fymoro said:
      Here is a fake ivy...From far in a exterior scene It should work not ? And setup in 2 minutes... ๐Ÿ‘
      You just gave me an idea, Fred... ๐Ÿ˜„
      (which I find to be an excellent idea, actually...)
      Since you can use Components from the scene together with this plug-in, you can take the texture of an Ivy leaf, create a component and "spray" that on the surface...
      I have a model, where I need to make a pavilion (or whatever it's called in English) made of metal tubes and where Ivy covers it...
      I've been struggling with Ivy Creator, but this can actually do the job... ๐Ÿ˜
      Cheers
      Kim Frederik
      • F Offline
        fymoro
        Yes Kim, It's great idea. This Plugin is awesome... ๐Ÿ‘
        http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
        • RichardR Offline
          Richard
          Yep that will do the job and very well!!!
          BUILTBRAND.COM.AU
          • FrederikF Offline
            Frederik
            With this plug-in, I finally succeeded making my ivy pergola...
            I had never dreamed that I would be able to do it inside SU...
            I used two ivy leaves from the "English Ivy" in Solo's Garden pack 1, made it a component and used the fur plug-in to "distribute" it onto a frame... ๐Ÿ˜„
            Cheers
            Kim Frederik
            • F Offline
              fymoro
              Well done, thanks for the tips Kim... ๐Ÿ‘
              Please can you make a small tuto ? ๐Ÿ˜’
              • massimoM Offline
                massimo Moderator
                5 min of work...and raw SU output. Really an amazing plugin ๐Ÿ˜„
                • FrederikF Offline
                  Frederik
                  It's really easy, Fred... ๐Ÿ˜„
                  Like I wrote earlier... In my example, I used the English Ivy from Solo's Garden pack...
                  1.) I exploded the model and deleted everything except 2 ivy leaves.
                  2.) Make these two leaves into a component.
                  3.) Open the Fur setting dialog
                  4.) You'll need to play around with the settings. My input in the "Density" box was 1000
                  5.) In the "Make by ComponentInstance" you select the Ivy leaves from the list
                  6.) Select the surface where you want the leaves to be
                  7.) Click "Make Fur" button.
                  Voila...! ๐Ÿ˜„
                  Cheers
                  Kim Frederik
                  • F Offline
                    fymoro
                    Wow!! Massimo, very cool !!!
                    Thanks for the totu Fredy... ๐Ÿ‘
                    • RichardR Offline
                      Richard
                      Mate when you look at images like that you wonder why SU cant have a better lighting environment, that would do us! Begone all renders!
                      BUILTBRAND.COM.AU
                      • massimoM Offline
                        massimo Moderator
                        Glad you like it. ๐Ÿ˜„
                        Totally agree Richard! ๐Ÿ‘
                        • michaliszissiouM Offline
                          michaliszissiou
                          @massimo: great modeling anyway ๐Ÿ‘
                          @richard: SU 2d export is my favorite too, especially combining 2-3 outputs in PP. You know this very well lol. Is it so difficult to write a plug-in that will just export one shadowed render mixed with another without shadows light from the opposite side, plus a z-map (via fog)... I suppose to do it manually is better. ๐Ÿ˜Ž
                          • massimoM Offline
                            massimo Moderator
                            The single models of ivy's leaf and grass's stem are from 3d warehouse, Michalis. I've used them in connection with the fur plugin to make the meadow and the climbing plant. ๐Ÿ˜‰
                              michaliszissiou
                              Yeah massimo, still a nice scene, not like this one. I just quick tested the plug-in, used the png from ivy generator. I'll paint something better, 3-4 leafs could be fine. What I have in mind is a fig tree (mediterranean), at last.
                              Ivy generator is fine but not for SU use.
                                ๐Ÿ˜„
                                • N Offline
                                  nektares
                                  heยดs got this Rod Stewart kinda feeling to me lol
                                  lol
                                  • soloS Offline
                                    solo
                                    ๐Ÿคฃ
                                    Brilliant one.
                                    http://www.solos-art.com
                                    • F Offline
                                      flipya
                                      Lucky Tiger ๐Ÿคฃ
                                      • F Offline
                                        fymoro
                                        OMG!!! ๐Ÿคฃ Should be great for me... ๐Ÿ˜ณ
                                          August
                                          As inspiration to take Make Fur in a totally different artistic direction, some of the sketches in this sketchbook make me think of Make Fur and Component Spray.
                                          Here's the link to the whole sketchbook and a sample image from it is attached below.
                                          As Jean says, Just Ideas...
                                          โ€œAn idea, like a ghost, must be spoken to a little before it will explain itself.โ€
                                          [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
                                            A very "rough" grass & ivy combo (Twilight Render until I came home from my "Corner Bar"...)
                                            Model by "Kephalos", ivy by Majid, background (#4) by Olishea (thanks all).
                                            • 8
                                            • 9
                                            • 2 / 9
