    Plugin needed: calculate countour length
    6 Posts 4 Posters 895 Views 4 Watching
    • liquid98L
      liquid98
      I'm looking for a sketchup plug-in to calculate the contour length of a 2D plane, like for instance this:
      http://lh5.ggpht.com/_P7FrbhzJzPM/S9gs3ROjrKI/AAAAAAAAAhY/QqXn61VGVgg/s800/Untitled.jpg
      must be easy, but I couldn't find a plugin myself.
      Any help would be appreciated.
      Things that flourish fall into decay. This is not-Tao, And what is not-Tao soon ends ~ Lao tse
      • GaieusG
        You don't need a plugin for that. See attached.
        • liquid98L
          liquid98
          Hi Gaieus,
          Thank you very much for the quick help! So I just select the lines en not the plane, and than read the data
          from the entity info. Great !
          Good luck!
          • GaieusG
            Yes, just the bounding edges. The double click > extract from selection second click is only needed when your bounding edges are not one, continuous polyline (but exploded for instance).
            • M
              mac1
              Cautionary Comment
              In some cases the info you get from the entity info is a theoretical length and not " segment length". For example draw an arc at a given radius, measure the angle and check the entity info and the answer one gets is d= r X theta ( theta in radians). Explode the curve and the entity info will now give you the sum of the segment lengths. I don't know how many tools do this.
              • thomthomT
                I expect only circle and arc segments.
