    Plugin needed: calculate countour length
    6 Posts 4 Posters 795 Views 4 Watching
    • liquid98L Offline
      liquid98
      I'm looking for a sketchup plug-in to calculate the contour length of a 2D plane, like for instance this:
      http://lh5.ggpht.com/_P7FrbhzJzPM/S9gs3ROjrKI/AAAAAAAAAhY/QqXn61VGVgg/s800/Untitled.jpg
      must be easy, but I couldn't find a plugin myself.
      Any help would be appreciated.
      Things that flourish fall into decay. This is not-Tao, And what is not-Tao soon ends ~ Lao tse
        You don't need a plugin for that. See attached.
        • liquid98L Offline
          liquid98
          Hi Gaieus,
          Thank you very much for the quick help! So I just select the lines en not the plane, and than read the data
          from the entity info. Great !
          Good luck!
            Yes, just the bounding edges. The double click > extract from selection second click is only needed when your bounding edges are not one, continuous polyline (but exploded for instance).
              mac1
              Cautionary Comment
              In some cases the info you get from the entity info is a theoretical length and not " segment length". For example draw an arc at a given radius, measure the angle and check the entity info and the answer one gets is d= r X theta ( theta in radians). Explode the curve and the entity info will now give you the sum of the segment lengths. I don't know how many tools do this.
                I expect only circle and arc segments.
