    Downloading Sketchup 7
    3 Posts 3 Posters 266 Views 3 Watching
      Lemastre
      I have SU version 6.4.245. If I download version 7, does it modify version 6, or do I end up with both versions? This question nags me every time I download a later version of any application, not just SU.
        SU7 creates a whole new folder structure therefore you can have both 6 & 7 simultaneously. It won't overwrite anything so you'll only need to migrate copies of any plugins you use over to 7's plugin folders.
        Oh and this is from a PC point of view, I don't like fruit!
          Yes, I also have SU 6 installed (and separately licensed). Then I also have SU 7.0 and 7.1 separately installed, too (although their licensing is not separate). So you can have a whole bunch of versions installed separately and you can even run them together if you wish.
          Note that if you double click on an skp file (and launch SU this way) it will always try to launch the version you saved anything in last.
          Also note that while you can open SU 6 files in SU 7 (and even "save as..." a v.6 file), you cannot open a v.7 file in SU 6.
          I think that's all.
