    Toughest modeling...
    5 Posts 2 Posters 589 Views 2 Watching
    • P Offline
      pixelmonkey380
      so i have found 2 objects that are amazingly difficult to model!
      1. Motocross Helmet
      2. Drive shaft Yoke
      want something to rack your brain? try taking on a modeling of a Shoei or Fox motocross helmet.
      want something a bit less frustrating? try a yoke! everytime I get it to look right, its poly count is extremely high!
      just venting
      chris<pixelmonkey>:D
      • soloS Offline
        solo
        Really?
        Got any good reference images?
        maybe a 'Model this' challenge will bring solutions.
        http://www.solos-art.com
        • P Offline
          pixelmonkey380
          @solo said:
          Really?
          I doubt any attempt under 30 minutes will be close to the below helmet.
          the Shoei VFX-W
          http://www.motorcyclehelmet.com/images/helmets/0145-0109-02.jpg
          https://www.dirtbikebitz.com/images/products/helmets/shoei/2010_Shoei_VFX-W_K-DUB_TC-6.jpg
          30 minutes on the yoke is possible, but to get it looking correctly might take a bit more time.
          as for a yoke... more photos if you click on the images.
          http://image.mustangandfords.com/f/9627651/mufp_0601_15z+ford_driveshaft+yoke.jpg
          http://image.mustangandfords.com/f/9597343+w750+st0/mufp_0601_04z+ford_driveshaft+aluminum.jpg
          there ya go! Challenge AWAY!
          • soloS Offline
            solo
            The 'Model this' challenge is not time restrictive, you can take as much time as needed to get it right, the point is when you do succeed that you share your technique with everyone so that it works like a learning thread.
            • P Offline
              pixelmonkey380
              doh! i was thinking of the speed modeling challenge being the same as the 'Model this' challenge
              thanks for the correction
