    Sketchup.write_default needs escaping?
    7 Posts 3 Posters 607 Views 3 Watching
    • thomthomT
      Here's an extract from my code:
      filename = Sketchup.read_default(S_SECTION, 'datafile')
      puts "\nread_default; #{filename}"
      if filename.nil? || !File.exist?(filename)
        filename = UI.openpanel('Choose NCS data file')
        puts "UI.openpanel; #{filename}"
        return nil if filename.nil?
        Sketchup.write_default(S_SECTION, 'datafile', filename)
      The code tries to get the filename from stored settings.
      If no settings is found or the file does not exist it will prompt the user for a file.
      On the first run, when it prompts for the file - everything works fine.
      But the next time it fail.
      read_default: C:Users hm.ARCDesktopNCS-RGB-HTML.txt UI.openpanel: C:\Users\thm.ARC\Desktop\NCS-RGB-HTML.txt
      The string I passed to write_default is not the same as the one I get when I read it.
      Looks like it evaluates the string and treats the backslashes as special characters.
      I can't find that behaviour described in the docs. Have I missed something, or is it a bug?
      • TIGT
        I think it's 'buggered'.
        I've noticed it messes with backslashes. πŸ˜’
        You could try doing a 'translation' of the \ to something else as you write and read...
        say writing as...
        filename.gsub!(/\\/,':')
        on reading it make all of the : into \ then make the first \ back to : to preserve the drive letter...
        filename.gsub!(/:/,'\\').gsub!(/\\\\/,':\\')
        PS: I chose : as it seems not to be messed with AND as it isn't allowed in file names etc it won't clash; and the double :: let's you easily revert the drive as C:\ etc...
        • thomthomT
          To work around this I just added filename = File.expand_path(filename) which converted \ to /.
          But I just wanted to check if it really was a bug in the API.
          • thomthomT
            And it is the read_default method that is bugged - because the registry setting is correct.
            • thomthomT
              Is this a new bug?
              • TIGT
                Don't expect so...
                • M
                  MartinRinehart
                  I had no end of troubles with slashes. Finally implemented this none-too-clever code and all the bugs went away:
                  =begin
                  qq() and qq!() do these replacements;
                      "'" -> "qq1"
                      '"' -> "qq2"
                      '/' -> "qq3"
                      '\' -> "qq4"
                      '\n' -> "qq5"
                      '\r' -> "qq6"
                  =end
                  def self.qq( str )
                      return str.gsub(
                          /\'/, 'qq1' ).gsub(
                          /\"/, 'qq2' ).gsub(
                          /\//, 'qq3' ).gsub(
                          /\\/, 'qq4' ).gsub(
                          /\n/, 'qq5' ).gsub(
                          /\r/, 'qq6' )
                  end # of qq()
                  def self.qq!( str )
                      str.gsub!( /\'/, 'qq1' )
                      str.gsub!( /\"/, 'qq2' )
                      str.gsub!( /\//, 'qq3' )
                      str.gsub!( /\\/, 'qq4' )
                      str.gsub!( /\n/, 'qq5' )
                      str.gsub!( /\r/, 'qq6' )
                  end # of qq!()
                  These reversers complete the Ruby:
                  def self.unqq( str ) # reverses qq()
                      return str.gsub(
                          /qq1/, '\'' ).gsub(
                          /qq2/, '"' ).gsub(
                          /qq3/, '/' ).gsub(
                          /qq4/, '\\' ).gsub(
                          /qq5/, '\n' ).gsub(
                          /qq6/, '\r' )
                  end # of unqq()
                  def self.unqq!( str ) # reverses qq!()
                      str.gsub!( /qq1/, '\'' )
                      str.gsub!( /qq2/, '"' )
                      str.gsub!( /qq3/, '/' )
                      str.gsub!( /qq4/, '\\' )
                      str.gsub!( /qq5/, '\n' )
                      str.gsub!( /qq6/, '\r' )
                  end # of unqq!()
                  These are the reversers in JavaScript:
                      single_quote = String.fromCharCode( 39 );
                      double_quote = String.fromCharCode( 34 );
                      ford_slash = String.fromCharCode( 47 );
                      back_slash = String.fromCharCode( 92 );
                      function unqq( msg ) {
                          s = msg.replace( /qq1/g, single_quote );
                          s = s.replace( /qq2/g, double_quote );
                          s = s.replace( /qq3/g, ford_slash );
                          s = s.replace( /qq4/g, back_slash );
                          s = s.replace( /qq5/g, '\\n' );
                          s = s.replace( /qq6/g, '\\r' );
                          return s;
                  Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
