    Floor-Wall Problem
    3 Posts 3 Posters 341 Views 3 Watching
      smhbrv
      Hello. I have got a problem.
      I create my project. It has got 2 Floors. I use "Push/Pull and raise each one.
      Then, I put them one after the other. When I delete exterior floor line, some lines get lost interior.
      How can I solve this problem.? Is there any way to make it.?
      (Plans are from Autocad.)
      Thank you.
      http://i39.tinypic.com/anhpcp.jpg
      http://i42.tinypic.com/35dcbk1.jpg
        Seems like you have deleted too much...
        Remake the missing parts by pushpulling the missing wall/rooms [again?] - our perhaps use a extrude-line or EEbyVector plugin tools...
        Sometimes CAD plans are not drawn perfectly and so there are gaps in the 'edges' and not therefore discrete faces ?
        πŸ€“
          From what I can see, redrawing a couple of lost edges would do it (as the rest is still there). Best suggestion would be to always group floor-plans and extruded wall (and on top of these, additional floors/ceilings and walls of second floor walls) grouped separately. Certainly you would end up with a couple of repeated, Z-fighting faces but only at spots that cannot be seen otherwise.
