    Can't view Woodworking forum
    5 Posts 5 Posters 419 Views 5 Watching
    • D
      Dadoing
      I registered and logged in. When I return to the SketchUcation page, the only place I can see the Woodworking link is in a box at the bottom of the page. When I click that link, I get "You are not authorised to read this forum." What is the fix? Thanks.
      Problem with Sketchup is it's more fun than cleaning up sawdust and sharpening tools.
        Use your 'User Control Panel' to add extra forums to your account.
        Under the 'Usergroup' tab you can select and save desired extra forums to see from Index
        • K
          kostas_designer
          hmm. I too don't see any other choices... 😕
          • C
            chrisjk
            PM Gaieus - he'll fix it for you
            Chris
            • GaieusG
              I see that the OP (Dadoing) is already a member of the woodworking UG. Kostas, you mean you would also like to be a member but cannot find your setting page? I guess this link should work for you (and everyone of course):
              http://forums.sketchucation.com/ucp.php?i=167
