    [Plugin] nudgeOrbit
    11 Posts 8 Posters 15.9k Views 8 Watching
      Copyright 2010 (c), TIG
      All Rights Reserved.
      THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
      WARRANTIES,INCLUDING,WITHOUT LIMITATION,THE IMPLIED WARRANTIES OF
      MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      nudgeOrbit.rb
      This tool orbits the current view around a set point in preset angle
      increments.
      To use it activate its toolbar 'nudgeOrbit' from the Views > Toolbar
      Menu if it's not already open.
      Click the 1st button on the toolbar, 'nudgeOrbit', the view then steps
      around by the specified angle. Keep clicking to move around...
      To change the step-angle click the 2nd button 'nudgeOrbit Settings' on
      the toolbar. In the resultant dialog enter a new angle - it can't be
      zero - if it's a +ve number it steps clockwise and a -ve number it
      steps counter-clockwise - the angle defaults to 15 degrees [clockwise]
      when the model is opened, but any new angle is remembered during that
      session until it's changed again.
      The camera's 'target-point' can be set is several ways.
      If there is a selection then it overrides any other settings and its
      bounding-box center will be used as the target-point; otherwise you
      can use the 'nudgeOrbit Settings' dialog [as explained above] and set
      the 'Target' to 'CameraTarget' or 'Origin' - the default is the
      model's Origin [0,0,0]. The Target setting is remembered that
      session.
      Tip: to specify an arbitrary 'point' as the target draw a 'cross' of
      lines or even a guide-point at that location and pre-select just that
      one thing, then the view will target in on its 'center'.
      Remember too that you can save any view you make as a Scene Tab using
      the built-in Sketchup tools...
      SketchUp Plugins | PluginStore | SketchUcation
      SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
      (sketchucation.com)
      • bagateloB Offline
        bagatelo
        I like the plugin. Congratulations.
        If is possible to set invert direction keys, can be
        interesting.
        Did you see this?
        http://forums.sketchucation.com/viewtopic.php?f=180&t=24586
          With this tool's methods you simply reset the angle to a negative value so 15 becomes -15 and the orbit becomes 'counter-clockwise'...
          • MALAISEM Offline
            MALAISE
            Still activ Plugin's Maker ! Great thanks TIG 😄
              d12dozr
              Very nice, TIG! ...also could be useful in setting up scenes around an object to do a rotating rendering 👍
              http://goo.gl/f7ooYh
                steel.monkee
                Thanks again, TIG. Can't wait to use it.
                Kapag maiksi ang kumot, matutong mamaluktot.
                  mmscanlo
                  SUPER useful - thanks!
                    tomsdesk
                    WOW! TIG, this will save me much cursing penance and some carpal tunnel pain as well...thank you very much! What SU versions are cool?
                    2.5D Trees & Shrubs!
                      All current and recent that you are likely to want to use [perhaps even back to v5?]
                      • jojo9J Offline
                        jojo9
                        Hi Tig,
                        I used your NudgeOrbit tool some times only, but I like it very much. The reason I used it so few is because NudgeOrbit converts always the Orthogonal view in Perspective view.
                        Perspective view is only good for Presentation purposes in my eyes, but to work i keep always the Orthogonal view.
                        I tried to understand how to interact with the current camera command too, but I wasn't able to figure out how to deactivate the perspective view. NO chance. 👊
                        If you're so kind to remove the perspective view or to leave the current camera as it is without switching to a particular view…that would be nice!
                          Here's a new future-proofed update.
                          http://sketchucation.com/forums/viewtopic.php?p=238647#p238647
